cat 6509 dual sup1A issue
Dear Netpros,
Please help me to solve the issue with 6509 sup1A.
The problem is as below.
sup1A running in native mode with IOS c6sup11-jsv-mz.121-26.E3.
When i individually booting the suP1A it is all ok.Also the red forced-switchover working .
When i cold reboot the chassis then only the active in slot 1 comes up and the slot 2 sup1A fails with the following
STATUS LED ORANGE
SYSTEM LED GREEN
ACTIVE LED NIL
PWR MGMT LED RED
SWITCH LOAD LEVEL : DOWN 2 LINE SHOWS GREEN BARS.
Also in hyperterminal console no message.
I have to do the following to get the sp rommon>
Press the reset button on the 6509 front chassis then in console press ctrl+break to get SP rommon.Here enter boot slot0:c6sup11-jsv-mz.121-26.E3.It boots
Please what went wrong for not normal booting during cold reboot.
swamy
Silver
Re: cat 6509 dual sup1A issue
Hi Swamy ,
Please check the config register setting on the standby supervisor by entering:
#remote login switch
#show version => look for the config-register.
It may have been corrupted and be something like ?0x0?.
If so enter:
#config terminal
#config-reg 0x2102
#exit
#write memory
Hope it helps you.
satish
Hi satish,
Router#remote login switch
Trying Switch ...
Entering CONSOLE for Switch
Type "^C^C^C" to end this session
Please the config given below
Router-sp#sh bootvar
BOOT variable = slot0:c6sup11-jsv-mz.121-26.E3,1
CONFIG_FILE variable =
BOOTLDR variable = bootflash:c6msfc-boot-mz.121-26.E3.bin
What else i can check.
swamy
Hi Swamy,
is that the output from the active sup or the standby sup. If that is the output from the active sup, then please paste the output of " show bootvar from the RP.
If that's the output from the standby sup, then you are missing the .bin extension in the filename given in the BOOTVARIABLE. Please set the vaiable again with the .bin extension in the filename, I think it should be Ok after that.
-amit singh
203
