Webcast-Catalyst9k
Cat 6k:Inline Power Module - PS volatage bad, cpu @ 85%
My Cat6k running hybrid mode 8.x in the Sup32 is giving the below error and pushing the cpu to 85%.
SYS-3-SYS_LCPERR3:Module 4: Inline Power Module - PS volatage bad: Module needs troubleshooting or
Is there any method to stop this module logging the 100's of message per hr? I don't use inline power for anything. The error logging is over driving the CPU.
We plan to replace it, but it will be several days before this is possible.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cat 6k:Inline Power Module - PS volatage bad, cpu @ 85%
Hello Doug,
if you don't use the module 4 you could
set module power down 4
otherwise you need to disable logging to your telnet session
set logging session disable
and to your console
set logging console disable
or you can try to change the severity level
set logging level sys 6
for more details see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/logging.html#wp1020288
Hope to help
Giuseppe
1 REPLY
Hello Doug,
and to your console
Hope to help
Giuseppe
978
