Community Member
cat express 500g login
We have a cat express 500g and I have assigned it a 10 dot ip address. Now in the intitial setup when you press the setup button you have to have the computer you are going to use to configure the switch, set up to automatically obtain an IP from the switch.
Since I have a IP already configured though, when I go to push the "setup" button, should I configure the computer with an IP on that network or should I get the IP automatically? If I get it automatically, what address do I put in the browser?
1 REPLY
Re: cat express 500g login
218
