CAT OS needed for C6509
Hello Gurus,
I tried Software Advisor and Cisco Software Search to look for an updated OS for my present CAT OS: cat6000-sup.5-4-2.bin
I need a much updated CAT OS that will support the following cards:
WS-X6K-SUP1A-2GE
WS-X6408A-GBIC
My available memory is as follows:
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1       65408K  42541K  22867K  16384K   6851K   9533K  512K  211K  301K
SWITCH (enable) show version
WS-C6509 Software, Version NmpSW: 5.4(2)
Copyright (c) 1995-2000 by Cisco Systems
NMP S/W compiled on Apr  7 2000, 15:48:28
System Bootstrap Version: 5.3(1)
Hardware Version: 2.0  Model: WS-C6509
By the way is it possible to migrate this to Cisco IOS based on the cards presented above?
Thanks in advance!
Everyone's tags (4)
1 REPLY
Purple
Re: CAT OS needed for C6509
    You need version  6.4.11 or later to support those cards  .  If you are going to upgrade you might as well upgrade to the last version of catos they ever made which is 8.7.3  .   Verify your gear has enough ram , flash and the rommon is ok .   Not sure if its possible to convert a Sup1a to Native ,maybe someone else can chime in , seems like it had to be  Sup2 or higher...
407
