Cat OS-TACACS plus
we have new switches using Cat OS TACACS plus, I have a script manipulating information from different switches, the one using using IOS TACACS no problem. unfortunately my script unable to log to the switches using CatOS TACACS plus. keep rejected. any body experiences the same problem and got any solution. or at least what's main difference between the two TACACS and what what I should look to write new scripts. thanks
Re: Cat OS-TACACS plus
Elias,
I would recommend you post this question on the NMS Forum (under Network Infrastructure).
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
thank you Sir!
140
