Dear Pros,
I have single 6509 chassis with single power supply and a sup1A.The sup running with cat os hybrid. I have blank pc card .I need to copy the cat os to the pc card.Note here that i have no line modules to tftp the image to pc card. Is there any command in the SP mode (console> (enable))to use to copy the cat os to the pc card (slot0:)
I tried copy flash slot0: gives error
but dir slot0: gives the output.
Please let me know how can i copy the image ?
Also one more question that IF i want to edit the SP rommon to change the boot variable like BOOT=slot0:cat6000-sup.6-3-3.bin.from BOOT=bootflash: Will the switch work?
swamy
