CAT3560x and OSPF (IP BASE)
I have 3560x switch with IPBASE image
c3560e-ipbase9-mz.150.1.SE
I cannot enable OSPF, why?
#.....router ospf
does not work
Please help
Purple
This image is not appearing in the list of supported images for OSPF on the Cisco feature navigator site.
Regards.
Alain
You need to have the following version to run OSPF.
c3560-ipservicesk9-mz.122-50.SE.bin
Please rate the helpfull posts.
Naidu.
Bronze
Hi Recep,
In order to use OSPF on a layer 3 switch, you require an IP Services / Universal Image.
IP Base is basic routing (Static / RIP etc) no VRF capabilities and several other restrictions.
IP Services opens up Advanced Dyanmic routing (OSPF / EIGRP / BGP / IS-IS), VRF-Lite etc.
If you have a valid support contract you should be able to download an appropriate image from
http://www.cisco.com/cisco/pub/software/portal/select.html?&i=!m&mdfid=282895848
However on the X series you cannot simply drop whatever image you like onto the device - you will need to purchase the relavent License first.
Hope that Helps,
Nick
Guys,
with 3560-X and 3750-X, OSPF for routed access is supported in IP Base image. It supports upto 256 OSPF routers.
Please see below.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933_ps10744_Products_Q_and_A_Item.html
To the original Poster, Please could you paste the " show version " from your switch.
Cheers,
-amit singh
Bronze
Re: CAT3560x and OSPF (IP BASE)
Hi Amit,
That's interesting - I wasn't aware of this, however I've done some further reading.. specifically here where it states:
"OSPF for Routed Access supports only one OSPFv2  and one OSPFv3 instance with a combined total of 200 dynamically learned  routes. The IP Base image provides OSPF for routed access."
Which I personally think is just terrible - I wouldn't have expected Cisco to be peddling Crippleware, which this effectively is.
I wouldn't therefore consider this as having OSPF, as it is crppled.  It may be suitable in a Stub area, or in a very small network.
One good thing is the following line:
"However, these restrictions are not enforced in this release."
So you should be able to use Full-Fat OSPF without restriction on that release (12.2(55)SE)  But don't rely upon it as Cisco will pull the rug out from under you in a future release.
So - Recep,
A nice easy one possibly....  have you enabled ip routing?
Nick
Bronze
Hi Recep,
Did any of the posts above answer your question?  If so, please rate any of the posts you found useful.
Nick
Silver
ive always had that same problem with ip base IOS images. features not working properly like the situation your experiencing now. i normally recommend that you download instead of an IPBASE, use adventerprise IOS images.
Posted by WebUser Julio C. Padilla
3560X Series IOS are common c3560e-universalk9, LAN Base,IP Base, IP Services, if you are a LAN Base level, need to do asimple OSPF, you need a License.lic file copied to the Flash, and then install.I tested it.
From China Hao
2428
