cat3750E Multicast PROBLEM (igmp join)
platform: WS-C3750E-24TD 12.2(44)SE2
C3750E-UNIVERSAL-M
running ip multicast rounting (for service iptv)...multicast source work ok and sending to multicast groups all ok!
test lab is:
my pc (vlc-player)<-vlan53->sw1<-vlan5->sw2<-vlan5->-sw3<--vlan100--> source multicast
configurations:
interface Vlan53
ip address x.x.157.9 255.255.255.248
no ip redirects
no ip proxy-arp
ip pim sparse-mode
no ip mroute-cache
interface Vlan5
ip address x.x.157.65 255.255.255.240
no ip redirects
no ip proxy-arp
ip pim sparse-mode
no ip route-cache cef
ip ospf mtu-ignore
load-interval 60
end
#sh ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
P - Proxy Capable, S - State Refresh Capable
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
x.x.157.71 Vlan5 1d05h/00:01:22 v2 1 / S (!! SW2 !!)
x.x.157.72 Vlan5 1d05h/00:01:32 v2 1 / DR S (!! SW3 !!)
sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter Group Accounted
224.0.1.40 Vlan5 02:36:18 00:02:12 x.x.157.71 Ac
#sh ip igmp interface
Global IGMP State Limit : 1 active out of 1 max
Vlan5 is up, line protocol is up
Internet address is x.x.157.65/28
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
IGMP query interval is 60 seconds
IGMP querier timeout is 120 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 1 joins, 0 leaves
Multicast routing is enabled on interface
Multicast TTL threshold is 0
Multicast designated router (DR) is x.x.157.72
IGMP querying router is x.x.157.65 (this system)
Multicast groups joined by this system (number of users):
224.0.1.40(1)
Vlan53 is up, line protocol is up
Internet address is x.x.157.9/29
IGMP activity: 0 joins, 0 leaves
Multicast designated router (DR) is x.x.157.9 (this system)
IGMP querying router is x.x.157.9 (this
sh ip pim rp
Group: 234.5.2.1, RP: y.y.112.2, v2, uptime 01:31:50, expires 00:02:52
Group: 234.5.2.2, RP: y.y.112.2, v2, uptime 01:31:50, expires 00:02:52
if on svi vlan53 use command:ip igmp static-group <ANY_GROUP>, on my pc see video steam!, else don't it (default) =>
see debug ip igmp:
IGMP(0): Received Leave from x.x.157.12 (Vlan53) for 234.5.2.1
IGMP(0): Received v2 Report on Vlan53 from x.x.157.12 for 234.5.2.4
IGMP(0): Received Group record for group 234.5.2.4, mode 2 from x.x.157.12 for 0 sources
IGMP_ACL(0): Group 234.5.2.4 access denied on Vlan53
access ports on switch to witch connect my PC not filtering multicast traffic,no filters,acl
Why not join to group in normal mode?
1 REPLY
Re: cat3750E Multicast PROBLEM (igmp join)
ALL thx, problem resolved!
my error - ip igmp limit 1
403
