cat4000-i9s-mz.121-19.EW1.bin
hello!
i have read a reply FROM Ankur that the switchover in the RPR Mode between 3 to 4 Mts & 30 to 60 Seconds in RPR +.but on my 4507R(2 Sup WS-X4515)i saw just RPR,.CAN I Upgrade my IOS To support RPR+?30 Sec its goof for Switch over
My Current IOS:cat4000-i9s-mz.121-19.EW1.bin
Re: cat4000-i9s-mz.121-19.EW1.bin
why not consider SSO?
Silver
You can upgrade to 12.2(25)EWA to have SSO and get <30s switchovers or 12.2(31)SGA code to support SSO with NSF, to have possible >5s switchovers. Here is the link for 12.2SGA SSO with NSF:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31a/config/nsfwsso.htm
Hi Ali,
I would suggest to use SSO with NFS between the supervisor engines. SSO/NSF give you sub-milisecond fail-over between the sup's for both L2/L3 failover though we claim it around 0-3 seconds which depends on the traffic flow. My self has tested same with 900Mbps traffic and the failover time was arnd 300 milisecond.
You need atleaset 12.2.31SG for the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31s/conf/nsfwsso.htm
HTH,
-amit singh
Hi Amit!
plz give the full name of the IOS
10XS
Hi!
do i need to update the IOS ON BOTH Supervisor or Just on 1 of them
10xs
ANY REPLY HERE
Hi Ali,
This is the full image name that you need on the box :
cat4500-ipbase-mz
HTH,
-amit singh
Hi Ali,
Have a look at this release notes for supported IOS 12.2(31)SG
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_release_note09186a0080758ff3.html#wp686916
Ankur
Hello Ankur;Hello Amit!
do i need to copy this IOS cat4500-ipbase-mz
TO Both bootflash on the 2 sup.or just on 1 bootflash???
plz send me the Link to to this
10xs
Hi Ali,
You have to copy the image on both bootflash.
This link will help you doing upgrade on both the supervisors.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a008036715c.html#wp1104060
Ankur
Ankur My Freind
10xs
478
