CAT4006 error message
I'm seeing following erorr on my CAT4006, I found the doc where it explains what the error mean but I can't find what does it mean stack type 2 and what type of process not avaialble. I have noticed issues on my blade 2 on the switch where some ports are not allowing DHCP addresses on them but I'm not sure if this erorr is related to that. If someone can point me to the right direction, I would appreciate it.
Thanks.
%KERNEL-1-CREATEPROCESSFAILED:Error in creating process: Unavailable free stack; stack type: 2; Name: tnetproc
1 ACCEPTED SOLUTION
Re: CAT4006 error message
Hi Nawas,
CatOS allows limited number of processes with type 2 stack in the system. The maximum number of processes with type 2 stack is 13. Telnet process is one of the process which require type 2 stack.
The switch will try to create process for new telnet connection if there is any type 2 stack available. When all type 2 stacks were used, any attempt on connecting through telnet results the error message "%KERNEL-1-CREATEPROCESSFAILED...".
We don't allow unlimited number of telnet connection to our device. Since the resource exhausted was stack, all other resources should still be unaffected.This is essentailly an informative message.
Ankur
Hi Nawas,
Ankur
Silver
Hi Nawas ,
%KERNEL-1-CREATEPROCESSFAILED: Error in creating process: [chars]; stack type:
[dec]; Name: [chars]
Explanation: This message indicates that the create process has failed; the system
is out of processes. The Catalyst operating system allows a limited number of processes
based on the number of stacks available. When stacks are unavailable, this message
is generated. The first [chars] is the process ID, the [dec] is the stack type,
and the second [chars] is the process name.
****Recommended Action: Issue the show users command to check how many telnet sessions
have opened for the switch. CatOS switch allows only a limited number of processes
with a type 2 stack (for example, Console, snmpdm, VtpRx, THREAD, telnet145) in
the system. The maximum number of processes with a type 2 stack is 13. To view
the type 2 stack processes issue the show proc command. These processes will
have the value 'xxxx/12288' under the 'Stacks' column. Telnet is one of the processes which require a type 2 stack. When all type 2 stacks are used, any attempt to connect through telnet will result in this error message. Disconnect the telnet sessions
opened by the remote device using the command disconnect {ip_address}. Also investigate
why so many connections are opened for the switch from the remote device.
check the below link.
http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_system_message_guide_chapter09186a00800e01f6.html#wp1015426
Hope it helps you.
satish
134
