Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cat4500-Sup V: AdjMan: hardware adjacency resources exhausted, performance
The following error message appears in my cat4506-SupV-12.2(20)EW4
%C4K_IOSIPROUTEMAN-3-ADJMANNOMOREADJS: AdjMan: hardware adjacency resources exhausted, performance may be degraded
Following that CPU usage rises to 99%
I found that this issue happens when I plug an internet router to the 4500.
The output of the show adjacency summary command shows that the adjacency table for that interface goes beyond 30K adjacencies. Is there any way to solve this kind of issue? anybody knows how this adjacency table works?
1 REPLY
Bronze
Re: cat4500-Sup V: AdjMan: hardware adjacency resources exhauste
My suggestion is to upgrade the code to the latest version, 12.2(25)EWA2. You can check
the release notes on the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html
146
