Community Member
Cat4500 What happened to reboot (help)
I was one day past the problems found.
one of the two to operate such equipment was rebooted.
two cat4500 is plugged into the same UPS electrical outlet
under a log server messages and crash information
attachments file - show tech
plz, help me
1. version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASE-M), Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 19:52 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11C44138
ROM: 12.2(44r)SG
Darkside Revision 4, Jawa Revision 18, Tatooine Revision 140, Forerunner Revision 1.71
OUT_DS01 uptime is 1 day, 19 hours, 31 minutes
Uptime for this control processor is 1 day, 19 hours, 31 minutes
System restarted at 15:02:36 KOR Sat Dec 21 2013
System image file is "bootflash:cat4500e-ipbase-mz.122-40.SG.bin"
cisco WS-C4507R-E (MPC8548) processor (revision 6) with 524288K bytes of memory.
Processor board ID FOX1203HAJU
MPC8548 CPU at 1.33GHz, Supervisor 6-E
Last reset from PowerUp
19 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
26 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
2. log server messege
2013-12-21 15:00:10 Local7 Warning  608: Dec 21 15:00:08: %C4K_SWITCHINGENGINEMAN-4-VFESUINTERRUPT: VFE SU adjStatsParityErr interrupt. valid: 1 addr: 0xC18 data: 0x1000 parity: 1
2013-12-21 15:00:41 Local7 Warning  609: Dec 21 15:00:38: %C4K_SWITCHINGENGINEMAN-4-VFESUINTERRUPT: (Suppressed 62 times)VFE SU adjStatsParityErr interrupt. valid: 1 addr: 0xC18 data: 0x1000 parity: 1
3. crash
Current Time: 12/23/2013 10:16:56
Last Power Failure: 12/19/2012 22:51:44
Last Reload Status: 00002000
Last Software Reset State: 00000000
Crashdump version: 1
Last crash: 12/21/2013 15:00:56
Build: 12.2(40)SG IPBASE
buildversion addr: 126F8B34
pc=113EC5C4 lr=113EC5C4 msr=02029200 vector=00000600
cr=82000044 ctr=11B4EB80 xer=20000000
r0=113EC5C4 r1=14A76060 r2=0000001E r3=00000029
r4=00000073 r5=00000000 r6=14A76028 r7=00000000
r8=00000001 r9=14A76099 r10=00000000 r11=11B4C79C
r12=CB1F7140 r13=528F93BA r14=11279874 r15=00000001
r16=12700000 r17=149B8364 r18=12700000 r19=149B8328
r20=149F1474 r21=12AD0000 r22=12200A24 r23=00000001
r24=149E4CDC r25=14A76270 r26=00000E50 r27=CB1F7148
r28=1666796C r29=14A76270 r30=14A76170 r31=14A76070
dec=0007EA7F tbu=0003BA60 tbl=C1C6F035
dar=80210020 dsisr=80210020 hid0=80004000
Traceback: 113EC5C4 11BAEC4C 113D4B7C 113D4BE4 112794B0 1127966C 11279824 112799B4 107335E4 1072A86C
Everyone's tags (2)
Re: Cat4500 What happened to reboot (help)
What you have seen are the correctable parity errors.:
Explanation    A parity error in the Very-fast Forwarding Engines's Statistics Update Module was detected. Contents of the log register are printed out. This is a parity error in one of the statistics counters.
Recommended Action    This is an informational message only. No action is required
In general that is usually transient if seen once or can be hardware problem in case of mulitple occurrencies. So if those errors are still happening please consider the replacement of Supervisor (RMA).
Here some details about parity errors:
Also the message on the show version **System returned to ROM by power-on** indicates that you can infer that the switch was either power-cycled, or that the power source went down for a few seconds. Verify your power source and troubleshoot the outlet circuit (power to switch).
