cat5000 switch vlan issue...
WS-C5000 Software, Version McpSW: 4.5(4) NmpSW: 4.5(4)
I am using above switch with below configuration.
1 2 100BaseFX MM Supervis WS-X5506 007397148 ok
2 24 10/100BaseTX Ethernet WS-X5224 007407779 ok
3 12 10/100BaseTX Ethernet WS-X5213A 006497822 ok
I have turned STP off on vlan 1(default) and connected uplink from root switch. Which work for vlan 1 (port 1/1 and 2/1-12) ports? I put UNIX box and works well with vlan1.
I have created another vlan and turned off STP. I have moved 1/1 and 2/1-12 ports to this new vlan. I moved my uplink to this new vlan and found no connectivity and I lost my uplink to my root switch. If I move this to vlan 1, it starts working. I don?t understand why it happening. Am I missing something when I created new vlan?
Thx.
1 REPLY
Re: cat5000 switch vlan issue...
add the new vlan to the trunk
135
