CAT6 on 100 MBPS
Hi all,
Can i run my PC on 100 MBPS connected with 100 MBPS of switch with CAT6 caling.
i am trying but it only works on 10 MBPS when i used CAT6 cabling.
Dhaval Tandel
Re: CAT6 on 100 MBPS
the cat 6 cabling should be up to 1Gb.
try checking the port speed or your NIC, else the cable isn't terminated good and has too much noise. or it's quality is poor.
MMOHANNI
i thinks its quality problem, because i have tried by manually setting the 100MBPS property for NIC, if i do so it stop working at all. it only works if i run it on 10 MBPS.
Dhaval Tandel
118
