CAT6500 VSS Dual-active detection fast-hello: ¿both endpoints?
rogelioalvez
Hello team:
The config guide says that you must choose and configure at least one interface (max of 4) on which DAD fast-hello is to be activated. Example:
Router(config)# interface fastethernet 1/2/40
Router(config-if)# dual-active fast-hello
Let´s suppose that this interface is connected to fastethernet 2/2/40 (on the other switch). ¿Do I need to configure the same previous command on the peer interface?
Your kind help will be greatly appreciated
TIA, Rogelio
2 Accepted Solutions
Reza Sharifi
Absolutely,  "dual-active fast-hello" command must be configured on both switches.
Simon Leigh
Hi there.
I would do at least two ports as recommended and if possible use different blade between the two chassis in case if hardware issues.
6 Replies 6
Reza Sharifi
Hi Reza:
I am Rogelio from someone else´s account. I am not being able to sign in with my username/password; I requested the password to be reset, but I can not reach the sign on system to make my password be changed.
Thank you very much for your kind answer.
Rogelio
Hi Rogelio,
Please rate and mark the post as answered, so others can benefit from it.
Reza
Simon Leigh
Hi there.
Hi Simon:
Rogelio
Simon Leigh
Hi Rogeilo.
Not a problem!
If you found the answer useful then please rate it
