cat6k sup720 question
we've cat6k with sup7200.
on sup720 there is 2 interfaces.is't possible to use both interfeces same time or only one.
I configured both, but the second interface is constantly down (in spite of no shutdown command).
Re: cat6k sup720 question
HI
As per the docs u can use any two ports on the sup out of 3.
Mahmood
You can use both of them. Look for some possible causes like:
1. GBIC module used is BAD/ Not working. Try using a spare GBIC
2. Cable is not good or wrongly connected. Make sure that you connect the fiber cable correctly and is a good one.
Sometimes the GBIC is not able to negotiate the speed correctly with the other end. Try using the command " speed nonegotiate " under the interface config of the GBIC interface.
HTH,Please rate if it does.
-amit singh
92
