11-26-2008 01:41 AM - edited 03-06-2019 02:41 AM
2 servers connect to 1Gb port at Cat6k.We made backup from one server to another and maximum speed at port near 200Mbps(it seems near 30 MByte per sec but Read/Write speed for hard disk is near 100 MByte per second).
Where can be problem? Maybe i need to enable
system jumbomtu at switch?
30 second output rate 183501000 bits/sec
There is not speed and duplex mismatch, no errors at ports.
11-26-2008 03:20 AM
Did you see the speed/duplex of the server?
Try to set the speed and duplex mode on both switch and servers, if you can..
I hope this helps.
Best regards.
Massimiliano.
11-26-2008 06:57 AM
