Catalyst 2900 XL
I have a Catalyst 2900 XL switch that is drop connection to computer connected to it. Is this switch repairable?
Hall of Fame Super Bronze
Re: Catalyst 2900 XL
Did you try connecting the computer onto another switchport ?
Do you see any errors on the switch console when that occurs ?
Based on your post, it's hard to know what needs repair. It can be a hardware issue but it can also be a software -or- configuration issue.
Yes, I have several computers on the switch. No matter which port is being use.
I have not check any error on the console. I do not have a monitor or pc connect to the console port.
What should I look for when using the console connection?
The log from the switch. Are you the person who configured the switches ?
In order to help you, you need to have some knowledge about IOS and switch configuration/troubleshooting.
If you don't, please get some onsite help.
243
