Catalyst 2948 SNMP
MrCheHMqm
Dear all, I spent almost a day in searching for the correct way to set up SNMP in cisco, but all I can find is setting the community for a traps receiver, which results that I can not send requests.
May I ask if any one can help me, so I can snmpwalk to the cisco router please?
I thank you all with all my heart.
Greetings
Che
6 Replies 6
glen.grant
Its no different than other devices just snmpwalk -c community string . This is on a unix box to a cisco catos device.
hmm, I'm sorry for not being totally clear. I know how the snmpwalk works. but the problem is, if I snmpwalk the cisco switch, I get no response, although the snmp is enabled.
The reason is that I have no read access to the snmp, because I have tried to use IP permit to give myself access.
so I searched the internet for help to update the snmp access list, like in an snmpd.conf on a net-snmp host, so that another machine has access to it.
conclusion is that I don't know how to do it in CatOS I guess, because a lot cli lines I have found started with "snmp-server" those do not work on this switch.
I need something like set snmp access or something, just so I can do an snmpwalk from a host to the switch :)
Thx in advance.
Greetings
Che
You have to configure a "permit list " for snmp on a catos box . This should help .
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/5.x/configuration/guide/ip_perm.html
done that one also. I have tried the "set snmp access" also by now, still doesn't work.
Perhaps I will have to reformulate my entire question to how do I set up snmp on a cisco, so that another host can snmpwalk to it (skipping the part of set snmp enable :p )
thx in advance
Greetings
Che
If you currently have "no" permit list configured and you a a valid configured read or RW string then there should be no restrictions on accessing the snmp data with a snmpwalk. Otherwise you may have to post config so that we can see whats in there.
This is the result from show snmp
ip permit is also set.
SNMP: Enabled
RMON: Disabled
Extended RMON Netflow: Disabled
Memory usage limit for new RMON entries: 85 percent
EngineId: some ID
Chassis Alias:
Traps Enabled: None
Port Traps Enabled: None
Community-Access Community-String
read-only somecommunity
read-write anothercommunity
read-write-all thebestcommunity
Additional- Access-
Community-String Access-Type Number View
Trap-Rec-Address Trap-Rec-Community Trap-Rec-Port Trap-Rec-Owner Trap-Rec-Index
someIP somecommunity somePort CLI 1
