Catalyst 2950 failed to reboot
Hi Sir/Madam,
Today I did a reboot for 1 of my Catalyst Switch 2950, But after reboot, I get nothing from console, And the SYST LED is amber, Does that mean there is a hardware issue in my switch? Thanks
Re: Catalyst 2950 failed to reboot
The LED option is "System LED is amber, and all port LEDs are off", It seems to be a corrupted software, Right, But I got nothing from Console,
How can I fix it? Thanks
I have the same Problem with one 2950 switch, it seems working for 10 weeks.
But whene update the software and reboot it, the switch crash with system led flashing and stat led green, and the console gives nothings..
note : fan and power are woking
Any solution ???
Thanks.
Purple
If you can't get anything out of the console to troubleshoot this further then your only option is going to be to get it RMA'd. I would try different speeds on your terminal emulator first to see if you can get any output from the console otherwise your options are limited.
352
