catalyst 2950 problem of memory
I have a cluster of 4 catalyst 2950.
The IOS is 12.1(22)EA12 with crypto and web device manager.
The SSH et HTTP server are activate.
The memory usage is always upper than 85%. Consequently, I get this message :
Nov 28 07:57:27: %SYS-2-MALLOCFAIL: Memory allocation of 98912 bytes failed from 0x803B6798, alignment 0
Pool: Processor Free: 49968 Cause: Not enough free memory
Alternate Pool: I/O Free: 341564 Cause: Memory fragmentation
How can I solve this problem ?
Re: catalyst 2950 problem of memory
Hi Hugo,
Is there any sort of like Network Control, MAC security or SPAN on it ?
DAK
No
However this switch is in a cluster (4 members).
Extract of show tech :
32768 bytes total (15169 bytes free)
------------------ show process memory ------------------
Total: 6065568, Used: 5327772, Free: 737796
PID TTY Allocated Freed Holding Getbufs Retbufs Process
22 0 760967264 760967080 3992 0 0 Calhoun Statisti
30 0 247568652 242761968 14116 4709116 4652896 IP Input
54 0 478374272 478371792 8988 0 0 Cluster Base
58 0 210309032 211563788 20616 0 0 Key Proc
75 0 2323718548 3152886732 132236 0 0 SNMP ENGINE
79 0 262488796 262488796 12808 0 0 Cluster Cmdr
5315252 Total
------------------ Mempool statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 80C86660 3885472 3849808 35664 1556 524
I/O A0A72240 2180096 1477548 702548 152676 365256
Could you please check if there is any change in STP configuration.
DAK
Hi Hugo,
Could you please paste show pro cpu sorted detail.
Chao
Vishwa
397
