05-02-2014 11:38 AM - edited 03-07-2019 07:18 PM
I have a Cisco Switch Catalyst 2950, nevertheless it does not have the option "crypto" in order for me to ssh to it. Any suggestion?
Version: #show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 26-Oct-10 10:35 by nburra
Image text-base: 0x80010000, data-base: 0x8057000
05-02-2014 11:46 AM
The image you have on your switch does not support crypto, if you want to use ssh to access it you will need to load a crypto image on it.
Javier Henderson
Cisco Systems
05-02-2014 12:28 PM
I have downloaded this: 1518 Mar 01 1993 00:40:55 +00:00 c2950-i6k2l2q4-mz.121-22.EA14.bin.
It looks like it is far smaller than the original 3132319 Mar 01 1993 00:02:42 +00:00 c2950-i6q4l2-mz.121-22.EA14.bin,
Now switch's flash shows: 2 -rwx 3132319 Mar 01 1993 00:02:42 +00:00 c2950-i6q4l2-mz.121-22.EA14.bin
3 -rwx 5 Mar 01 1993 00:40:55 +00:00 private-config.text
5 -rwx 1636 Mar 01 1993 00:28:52 +00:00 config.old
19 -rwx 1518 Mar 01 1993 00:40:55 +00:00 c2950-i6k2l2q4-mz.121-22.EA14.bin
7 drwx 704 Mar 01 1993 00:00:13 +00:00 crashinfo
16 -rwx 85 Jan 01 1970 00:04:29 +00:00 env_vars
When I was trying to boot from the new IOS version I went into great problems bring the switch back to it's function. I would appreciate any assistance on how to install the crypto image.
Kindest Regards.
05-02-2014 01:35 PM
What does that mean, great problems?
could u pls. Paste a show boot?
did u try to update it via "archive download-sw...."
05-02-2014 04:02 PM
Ok,here I go.
I've downloaded and installed the new " IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)" to get the "ssh" option. Used TFTP.
I did the boot system flash pointing to the new IOS version.
switch: boot
Loading "flash:c2950-i6k2l2q4-mz.121-22.EA14.bin"...#######
It rebooted normally with the new IOS version, nevertheless I got the "switch:" prompt nevertheless I don't have the command "enable". I got stuck with "switch:"
Now all the commands I have available are as below:
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_param -- Set system parameters in flash
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
-- MORE --
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
Please, any idea?
05-03-2014 04:18 AM
05-08-2014 04:21 PM
Actually I had not followed the upgrade process correctly. Thank you.
07-23-2015 02:17 PM
This discussion has been reposted from Top Contributors to the LAN, Switching and Routing community.
05-02-2014 08:54 PM
Did u check the RN for compatibility and requirements?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2950/software/release/12-1_22_ea14/release/notes/OL23783.html#wp999531
It seems u need to recover the Switch IOS..I don't have much experience with the 2950 but u should be able to reload the old imag via tftp via ROMON mode (switch:)
05-08-2014 04:19 PM
I had lost my switch configuration and IOS, fortunately I had the image on my computer and was able to restore it using xmodem option. Now everything is working fine. Thank you all.
