Catalyst 2950 with boot error
aussie008
Hi, I have a catalyst 2950-24 and  accidentaly uploaded the .TAR file instead of tge .BIN file. I had also,  deleted the previous IOS. I try to do an
xmodem and get this  error
switch:  copy xmodem: flash:c2950-i6q4l2-mz.121-22.EA12
Begin the Xmodem or  Xmodem-1K transfer now...
CCC
### Send (x)  c2950-i6q4l2-mz.121-22.EA12.bin: NAK on sector
### Send (x)  c2950-i6q4l2-mz.121-22.EA12.bin: Retry Count Exceeded
Also, when I  try to delete the .TAR file I get permission denied.
Any  thoughts?
7 Replies 7
I am sorry, I am a novice to this forum...I still getting the error message I stated earlier.
Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
I am using the procedure that is outlined in the url you sent. However when I do the copy xmodem: flash:c2950-i6q4l2-mz.121-22.EA12.bin
get the following error messages
### Send (x) c2950-i6q4l2-mz.121-22.EA11.bin: NAK on sector
### Send (x) c2950-i6q4l2-mz.121-22.EA11.bin: Retry Count Exceeded
xmodem:: I/O error
Issue the copy xmodem: flash:filename command on the switch.
Here is an example:
switch: copy xmodem: flash:c2955-i6q4l2-mz.121-13.EA1.bin
CCC
From the top of the HyperTerminal window, choose Transfer > Send File.
Choose the Xmodem protocol in the Send File dialog box and click Browse in order to select the Cisco IOS image (.bin file) that you downloaded previously.
Click Send in order to begin the Xmodem transfer.
That is what I am doing. I select xmodem and then select the file to send. As soon as the transfer starts I get the errors
Try downloading a different version of IOS.  It could be corrupt.  DO you have a TFTP server running?  And you are using HyperTerminal, right?
