Catalyst 2960 compatibility
I am new to Cisco switches world.
I have one Catalyst 2960 switch with 4 Gigabit ports.
Using gigabit ports with GBIC (1310nm), this cisco switch was not able to connect to D-link or 3Com switches with the same gbic model and port type.
But I could make 2 d-link switches talk to each other using the same optical fiber structure and port type. And the same with 2 3com switches.
Is there any kind of incompatibility between catalyst 2960 switches and other ones? Or is it misconfigurated?
Re: Catalyst 2960 compatibility
Can you try disabling auto negotiation of speed and duplex on both the switches and check again?.
How can I do that on Cisco switch?
Under the Gig interface configuration,
NativeIOS(config-if)#speed 1000
NativeIOS(config-if)#duplex full
Do the same on the other 3-com or D-link switches as well.
Purple
Unless they are cisco approved gbics they may not work in a cisco box. They should be cisco gbics.
233
