Catalyst 2960 - ip DHCP snooping VLAN
Ritter Rs
Hello to everyone,
I have some issue with DHCP snooping on Catalyst 2960.
I added some vlans:
ip dhcp snooping vlan 2,400,401,402,403
But it dosen't work.
All details:
Version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Configuration before:
SW13#sh ip dhcp snooping
Switch DHCP snooping is disabled
DHCP snooping is configured on following VLANs:
none
Insertion of option 82 is enabled
   circuit-id format: vlan-mod-port
    remote-id format: MAC
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Interface                    Trusted     Rate limit (pps)
SW13#sh ip dhcp binding
IP address       Client-ID/              Lease expiration        Type
                 Hardware address
#List of VLANs
SW13#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/17, Gi0/2
2    GUEST                            active
8    W-Int                            active
24   CONSOLES                         active
64   Inside                           active
100  WAN                              active
128  Mgm                              active
224  DMZ                              active
230  VoIP                             active    Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23, Fa0/24
400  FLOOR-0                          active    Fa0/6, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/13, Fa0/15, Fa0/16, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24
401  FLOOR-1                          active
402  FLOOR-2                          active
403  FLOOR-3                          active    Fa0/14
Then I've made DHCP snooping config:
Enter configuration commands, one per line.  End with CNTL/Z.
SW13(config)#ip dhcp snooping
SW13(config)#ip dhcp snooping vlan 2,400,401,402,403
SW13(config)#no ip dhcp snooping information option
SW13(config)#int gi 0/1
SW13(config-if)#ip dhcp snooping trust
# Gi0/1 is trunk
After config I've gotten this
Switch DHCP snooping is enabled
Insertion of option 82 is disabled
GigabitEthernet0/1           yes         unlimited
But also this:
SW13#sh run
ip dhcp snooping vlan 2,400-403
ip dhcp snooping
ip domain-name mydomain.local
ip name-server 192.168.10.10
  It works only for one VLAN, VLAN 2
  SW13#sh ip dhcp snooping binding
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
04:46:61:90:55:3D   192.168.102.27   3536        dhcp-snooping  2     FastEthernet0/1
Any help?
How to make it works for other vlans?
Is it problem related to IOS version, or something other?
Thank you.
Hello Jovan,
It looks like we are hitting software defect
CSCse03859 Bug Details
2960 : DHCP snooping does not work for vlan id greater than 255
Symptom:
On a 2960 series switch, dhcp snooping is not effective on vlans whose number
is greater than 255.
Conditions:
The switch is in VTP server mode when the VLANs above 255 are created.
Workaround:
Create the VLANs in VTP transparent mode before enabling them for DHCP Snooping.
Partha
5 Replies 5
Rolf Fischer
Level 9
Level 9
have you yet verified that VLANs 400-403 exist and are in active state (show vlan brief)?
Rolf
Yes, they are all in active state, that switch is a VTP client, I have another switches, some of them with another IOS version work fine, but switches with this version of IOS have this problem.
I've tried to reload, but without success.
Sincerely,
J
Hello Jovan,
Symptom:
Conditions:
Workaround:
Partha
Jovan,
Try to reconfigure dhcp snooping after changing the VTP mode to transparent. I believe currenlty the VTP mode is client,
Partha
Partha,
Thank you for your help.
Yes VTP mode is client, I didn't change mode to transparent because I need that switch in VTP client mode. I put new IOS version.
Just an IOS upgrade.
Now it's working.
Thanks, again.
Jovan.
