Catalyst 2960 - ip DHCP snooping VLAN
Hello to everyone,
I have some issue with DHCP snooping on Catalyst 2960.
I added some vlans:
ip dhcp snooping vlan 2,400,401,402,403
But it dosen't work.
All details:
Version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Configuration before:
SW13#sh ip dhcp snooping
Switch DHCP snooping is disabled
DHCP snooping is configured on following VLANs:
none
Insertion of option 82 is enabled
   circuit-id format: vlan-mod-port
    remote-id format: MAC
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Interface                    Trusted     Rate limit (pps)
SW13#sh ip dhcp binding
IP address       Client-ID/              Lease expiration        Type
                 Hardware address
#List of VLANs
SW13#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/17, Gi0/2
2    GUEST                            active
8    W-Int                            active
24   CONSOLES                         active
64   Inside                           active
100  WAN                              active
128  Mgm                              active
224  DMZ                              active
230  VoIP                             active    Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23, Fa0/24
400  FLOOR-0                          active    Fa0/6, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/13, Fa0/15, Fa0/16, Fa0/18, Fa0/19, Fa0/20, Fa0/21, Fa0/22, Fa0/23
                                                Fa0/24
401  FLOOR-1                          active
402  FLOOR-2                          active
403  FLOOR-3                          active    Fa0/14
Then I've made DHCP snooping config:
Enter configuration commands, one per line.  End with CNTL/Z.
SW13(config)#ip dhcp snooping
SW13(config)#ip dhcp snooping vlan 2,400,401,402,403
SW13(config)#no ip dhcp snooping information option
SW13(config)#int gi 0/1
SW13(config-if)#ip dhcp snooping trust
# Gi0/1 is trunk
After config I've gotten this
Switch DHCP snooping is enabled
Insertion of option 82 is disabled
GigabitEthernet0/1           yes         unlimited
But also this:
SW13#sh run
ip dhcp snooping vlan 2,400-403
ip dhcp snooping
ip domain-name mydomain.local
ip name-server 192.168.10.10
  It works only for one VLAN, VLAN 2
  SW13#sh ip dhcp snooping binding
MacAddress          IpAddress        Lease(sec)  Type           VLAN  Interface
04:46:61:90:55:3D   192.168.102.27   3536        dhcp-snooping  2     FastEthernet0/1
Any help?
How to make it works for other vlans?
Is it problem related to IOS version, or something other?
Thank you.
have you yet verified that VLANs 400-403 exist and are in active state (show vlan brief)?
Rolf
Yes, they are all in active state, that switch is a VTP client, I have another switches, some of them with another IOS version work fine, but switches with this version of IOS have this problem.
I've tried to reload, but without success.
Sincerely,
J
Hello Jovan,
It looks like we are hitting software defect
CSCse03859 Bug Details
2960 : DHCP snooping does not work for vlan id greater than 255
Symptom:
On a 2960 series switch, dhcp snooping is not effective on vlans whose number
is greater than 255.
Conditions:
The switch is in VTP server mode when the VLANs above 255 are created.
Workaround:
Create the VLANs in VTP transparent mode before enabling them for DHCP Snooping.
Partha
Jovan,
Try to reconfigure dhcp snooping after changing the VTP mode to transparent. I believe currenlty the VTP mode is client,
Partha
Partha,
Thank you for your help.
Yes VTP mode is client, I didn't change mode to transparent because I need that switch in VTP client mode. I put new IOS version.
Just an IOS upgrade.
Now it's working.
Thanks, again.
Jovan.
652
