Catalyst 2960 s Express Setup
I'm trying to set up my 2960-S (POE) switch with the express setup. I have used the express setup on multiple 2960-G (none-POE) switches and it has workd fine. However, when I use it on the POE, and I try to enter 10.0.0.1 in my browser it askes me for a username and password, which I dont have because this is the first time this switch has been set up.
On the none-POE switch it was inside the 10.0.0.1 window that I set up the username and password. Is there some default username/password for the POE version of the switch?
I have tried resetting the switch to factory configuration, and it still asks for the username/password after I enter express setup.
All I'm trying to do is set up the IP address, name, and password.
Thank you,
Erik
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Catalyst 2960 s Express Setup
Username:  Cisco
Password:  Cisco
Username:  Cisco
Password:  Cisco
Thank you, that did the trick!
Erik
Thanks for the ratings, Erik.  I'm glad to be of some assistance.
4121
