catalyst 2960G vlan configuration
shafitokhi
I have got a catalyst cisco 2960G series switch and via this switch I want to creat serveral vlans.
I am getting a dhcp IP from a router and I want to setup my own vlan networks.
I plugged in the Ethernet cable that came from the dhcp router to port 16 of the cisco switch and configured the ports 1,2 and 3 for vlan 1, 2 and 3
the dhcp router has given me this IP 192.168.10.158
defautl gateway is : 192.168.10.1
when I plug in a PC to port 1 or 2 of the cisco switch I still receiving the IP from range 192.168.10.* but not from the range that I configured for the vlan 1 or 2.
Below is my startup configuration:
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport access vlan 2
  switchport mode access
interface GigabitEthernet0/3
switchport access vlan 3
interface Vlan1
ip dhcp client lease 50 0 0
no ip route-cache
interface Vlan2
ip address 192.168.2.1 255.255.255.0
no ip route-cache
interface Vlan3
ip address 192.168.3.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
What I want is to get a dhcp IP from vlan based on the subnet that has been specified for subnet. e.g; If I plug in a PC to port 1 (vlan 1) then I expect to get an IP 192.168.1.*   - same case for other vlans.
I'm not sure if I have got the right configuration and really not sure if I have pluged in the Ethernet cable that came from the dhcp router to the right port (16 of the cisco switch) ?
Thanks in advance for your help.
Latchum Naidu
Hi Shafi,
To achive what you want you need to do below...
1. You need to specify the required address pools in your DHCP (Router) Server.
2. Specify the "ip helper-address "DHCP server address" under the required VLAN..
interface Vlan2
no ip route-cache
ip helper-address "DHCP server IP"
3. Configured the access port to which you are connecting PC on your 2960 to specific VLAN...
int fa2/4
switch-port mode access vlan 2
Please rate the helpfull posts.
Naidu.
28 Replies 28
Latchum Naidu
Hi Shafi,
interface Vlan2
no ip route-cache
int fa2/4
Naidu.
I followed the points that you have mentioned, now I can get a dhcp IP from the respective vlan, but I can't connect to the internet.
On step 3  I can't use the "fa" command on 2960G switch, I only can use the gigabitEthernet.
Below is how the startup config looks like: (dhcp scop only configured for Vlan 2)
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip dhcp pool dpool1
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
no file verify auto
i
interface Vlan1
no ip route-cache
interface Vlan2
ip helper-address 192.168.10.1
ip helper-address 192.168.2.1
no ip route-cache
interface Vlan3
no ip route-cache
ip http server
@ Reza Shrifi
Switch#sh ip int bri vlan 2
Interface              IP-Address      OK? Method Status                Protocol
Vlan2                  192.168.2.1     YES NVRAM  up                    down
Switch#sh ip int bri vlan 3
Vlan3                  192.168.3.1     YES NVRAM  up                    down
Reza Sharifi
Have you configured the DHCP scope for the other subnets (192.168.2.1 255.255.255.0 &192.168.3.1 255.255.255.0?
Are vlans 2 and 3 in up and up mode? try "sh ip int bri vlan 2"
any one?
Create multiple DHCP scope in your DHCP server/router corresponding to each VLAN.
I mean create a scope 192.168.2.0/24 for VLAN2 and 192.168.3.0/24 for VLAN 3 in the same DHCP server.
and put ip helper-address 192.168.10.1 in each interface VLAN configuration.
So whenerver a DHCP packet came from a client it will broadcast to the Corresponding VLAN and it will reach the DHCP server. So a broadcast packet for DHCp address in VLAN to will be destined to the broadcast address 255.255.255.255. So the DHCp server will understand it is asking for the a IP address in the range 192.168.2.0/24. So it will lease IP address corresponding to it.
Vipin
Thanks and Regards, Vipin
thanks for the reply,
I have already done that, as an example I have only configured this for the vlan2 but still i'm not able to connect to the internet via vlan 2
interface Vlan2
no ip route-cache
I probably need to delete the 2nd ip-helper, I didn't know the command how to delete the extra one.
any idea for the above configuration?
You can delete this by
r(config)#int vlan2
r(config-if)# no ip helper-address 192.168.2.1
Are you sure you made different scope for different vlans?
Vipin
Yes,
I have created seperate dhcp pools for each vlan and define the
ip helper-address 192.168.2.1 for each vlan, now I can get the ip but still can't ping.
same configuration as below goes for each vlan.
ip dhcp pool dpool1
   import all
interface Vlan2
no ip route-cache
I pluged in the internet cable to one fo the ports which is not configured for any vlans ( not sure if this is the right port?)
but I can't ping the default gateway ( 192.168.10.1)
Do I need to configure the port that the internet cable is pluged in? if yes any hint?
Many thanks.
post a diagram of the topology as well as running config of router and switch.
You can't go to internet from the switch or from PCs?
Alain.
Jon Marshall
edited
  I think a 2960 may be able to route with the newest IOS codes   .Make sure you have ip routing turned on if you do have the latest codes.  You said you plugged the internet into a port that wasnt configured so that means its in a port that is vlan 1 which I believe you already setup for another subnet .  The ip default gateway does nothing , this is used for managing the switch if ip routing is turned off .  I would remove that and see if it will take a default static route , 0.0.0.0 0.0.0.0 192.168.10.1 .
Glen
I edited my post because i wasn' totally sure about this.
I know with the latest code the 2960S switches can do basic routing.
Do you know if this also applies to the non S 2960 switches, because i can't find a definitive answer on this and don't have one to test with.
Jon
Thanks for the reply,
I'm not sure if I have the lates IOS on my router, I tried to perform dynamic routing, but the 2960G router could not recagnize the command. ( I think Ip routing is not enabled, and I don't have the clue how to make it enable)
When I connect to the vlan 2, I could get the dhcp IP but not able to ping the default gateway/google for instance ( both from router and PC).
below is the result of the route command on my PC:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         192.168.2.1        0.0.0.0               UG    0      0        0 eth0
link-local      *                       255.255.0.0         U     1000   0       0 eth0
192.168.2.0     *                   255.255.255.0       U     1      0        0 eth0
The complete startup file:
show startup-config
Using 3175 out of 65536 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
enable secret 5 $1$E2kH$zZbWhNiIphJNxxA8F3cB81
no aaa new-model
ip subnet-zero
ip dhcp pool dpool1
   import all
ip dhcp pool dpool2
   import all
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
ip dhcp pool dpool4
   import all
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
ip dhcp pool dpool5
   import all
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.1
ip dhcp pool dpool6
   import all
   network 192.168.6.0 255.255.255.0
   default-router 192.168.6.1
ip dhcp pool dpool7
   import all
   network 192.168.7.0 255.255.255.0
   default-router 192.168.7.1
ip dhcp pool dpool8
   import all
   network 192.168.8.0 255.255.255.0
   default-router 192.168.8.1
no file verify auto
interface GigabitEthernet0/4
switchport access vlan 4
interface GigabitEthernet0/5
switchport access vlan 5
interface GigabitEthernet0/6
switchport access vlan 6
interface GigabitEthernet0/7
switchport access vlan 7
interface GigabitEthernet0/8
switchport access vlan 8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface Vlan1
no ip address
no ip route-cache
interface Vlan2
no ip route-cache
interface Vlan3
no ip route-cache
interface Vlan4
ip address 192.168.4.1 255.255.255.0
no ip route-cache
interface Vlan5
ip address 192.168.5.1 255.255.255.0
no ip route-cache
interface Vlan6
ip address 192.168.6.1 255.255.255.0
no ip route-cache
interface Vlan7
ip address 192.168.7.1 255.255.255.0
no ip route-cache
interface Vlan8
ip address 192.168.8.1 255.255.255.0
no ip route-cache
ip http server
control-plane
line con 0
line vty 0 4
password nocnoc
login
line vty 5 15
password nocnoc
login
end
Router version:
Switch      Ports         Model                        SW Version              SW Image
*    1          24            WS-C2960G-24TC-L   12.2(35)SE5       C2960-LANBASE-M
Do I need to upgrade the IOS?
Thanks.
Hi Shafi,
You have a very old IOS. It was from 2007. I would definetly upgrade the IOS to newer version. The latest version is
c2960-lanbasek9-mz.150-1.SE.bin.
Once you upgraded the IOS then iIn the global configuration mode, enter the command
sdm prefer lanbase-routing
Then  save the configuration and reload the switch. After the reload, you  should be able to activate the IP routing and set up static routing  entries
and type ip route 0.0.0.0 0.0.0.0 192.168.10.1
In regards to your question about not able to ping the internet, you nee a public ip address on the device. This device should be connected to a router and that router should have a public ip address. Can you please paste your topology here?
Kishore
