Catalyst 2960s Stacking with different IOS versions
fuhrersk8
Level 3
Level 3
                   Hello Forum Team;
When adding a new switch with older ios version to an existing stack (flexstack) does the new switch will be able to join the stack?
Thanks in advanced!
Ankur Arora
In a stack/flexstack all the switches should have exact same IOS version, otherwise there will be a version mismatch on the stack and the new switch will not be able to join the stack.
The following Document contains more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578928.html
Ankur
"Please rate the post if found useful"
Hi, if your switch is 2960s you can add to stack, and your stack has the future of auto-upgrade  to upgrade all the switches in the stack and make the ios equal.
Check the link below for more detailed infos
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swstack.html#wp1166403
Hello and thanks for the reply guys;
   Correct.  I just went trhough it. So im upgrading the new switches manually.
Thanks again for your great support.
Ankur Arora
Ankur
