Catalyst 2960s vs Catalyst 3850
Brett Williston
I am a newbie so please excuse my ignorance.
We are bidding out a project.
Will the Catalyst 2960s be capable of terminating a fiber connection?
Reza Sharifi
The 2960 switches are mainly copper switches. The copper ports are used for end device connectivity e.g servers, PC, laptop, printers, etc..
and 2 fiber ports for uplinks
Are you looking for all fiber switch?
what are you trying to do?
Reza Sharifi
shillings
Level 4
Level 4
What are you connecting via fibre?
There is a 3750-X all-SFP switch (12 and 24-port options), but not a 3850 series.
Thank you everyone. My local vendor just explained to me the reason for the pricey 3850
Brett,
You are asking a "loaded" question.  Sure the 2960S/2960X and 3850 can terminate fibre optic.  It all depends on how you want it.
Both the 2960S/2960X and the 3850 can be stacked.  When we say "stacked" it means that the each switch models can be connected (at the back using a special stacking cable) to form a single logical switch.
Each 2960S can support a minimum of two SFP/SFP+ or up to four SFP.  The 3850, however, can support up to four SFP/SFP+ fibre.  This is on a single unit.
Before I continue droning on, what EXACTLY are you trying to do and achieve?
