Webcast-Catalyst9k
Catalyst 2960X Flexstack VPC to Nexus 5K's
Hi All,
I have searched this forum and cannot find anything similar to the scenario I am currently presented with.
Is it possible to create a VPC between a pair of Catalyst 2960X (24 & 48 Port) Flexstacked together back to a pair of Nexus 5596UP switches?
I know a single Catalyst 2960X can support this scenario but just wondered whether the flexstacking cable enables each 2960X to have a tengigabit SFP+ back to the Nexus 5K's.
Diagram attached for info.
Thanks in advance.
Mark
Update on this scenario provided bay Cisco TAC:-
On the 2960, you can create a cross stacked etherchannel (ie one port of the etherchannel on one switch and the other on the other switch in the 2960x stack)
Link: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12995/white_paper_c11-728327.html
On the nexus 5000, once you finish the following:
Enable the vPC feature.
Create a vPC domain and enter vpc-domain mode.
Configure the vPC peer keepalive link.
Create the vPC peer link.
You will have to configure to create a port channel:
1.    switch# configure terminal
2.    switch(config)# interface ethernet chassis/slot/port
3.    switch(config-if)# channel-group channel-number mode {active | passive | on}
On both VPC switches, add the port channel to the vpc:
2.    switch(config)# interface port-channel channel-number
3.    switch(config-if)# vpc number
Nexus 5k links:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/layer2/Cisco_Nexus_5000_Series_NX-OS__chapter8.html#topic_64BF925367764DFC9D100CF26D805D22
Feel free to contact me if you have any questions or concerns.
Darshan Karanth
Hey, I am doing same scenario
Hey, I am doing same scenario with Cisco Nexus 9k. I have IDF racks across the building with two 2960-x in each IDF connecting back to pair of Nexus 9k with single fiber run from 2960-x to one nexus.
need your thoughts on this
It is exactly the way your
It is exactly the way your picture shows.
1445
