12-18-2017 05:52 AM - edited 03-08-2019 01:08 PM
Now since my switch Cat 3560 Poe-24 has only 15 megs of Flash memory and latest catalyst software is approximately 20 megs in size, I just wondered is there any way of upgrading Flash module on the switch with more capacity?
Solved! Go to Solution.
12-18-2017 06:16 AM
Unfortunately, there is no option of expanding the FLASH memory in the Catalyst 3560 series switches. The ones with the 16MB FLASH can unfortunately be upgraded only to the 12.2(55)SEx releases; newer releases might exceed the available FLASH size.
I am sorry to bring in disappointing news :-\
Best regards,
Peter
12-18-2017 06:16 AM
Best regards,
Peter
12-18-2017 09:16 PM
12-18-2017 09:46 PM
12-18-2017 06:43 AM
12-18-2017 07:04 AM
Hi Joe,
I thought of the same thing - but to my best knowledge, unfortunately, Catalyst 3560 does not even support TFTP in the bootloader mode; the only supported file transfer protocol is Xmodem, and you can only copy the file to flash: but not directly boot from it.
Looks like there's no way here :-(
Best regards,
Peter
12-18-2017 10:48 AM - edited 12-20-2017 05:17 AM
As is so often the case, Peter is spot on. I.e. the 3560/3750 boot loader doesn't seem (to natively) support TFTP.
I don't have a 3560 to play with, but I do have a 3570G, running (55)SE11. Its boot loader only supports loading from flash or xmodem.
It also supports loading a helper file from flash, so in theory, if Cisco provided one, with such you should be able to extend boot loader options. I searched the Internet, and at least one other person sought such a helper file, but no one knew of one.
With a 16 MB 3750, in a stack with other 32 MB 3750s, one of the auto upgrade options (for example, boot auto-download-sw supports http, ftp and tftp) might do the trick, but of course, that's not possible with a 3560.
12-18-2017 01:12 PM
