Webcast-Catalyst9k
Catalyst 3560 - Windows Deployment Services - IP adress Problem
Hello
i'm using some catalysts 3560 with 10 VLANs and inter vlan routing.
we use a windows deployment services server to install our workstations.
the pxe boot works fine. the image is loading, and when the windows 7 PE is booting, the dhcp request failes.
when i use a small not manageable switch between the computers and the catalysts, it works fine.
all other things work fine.
do you have any ideas?
best regards
Andreas
Everyone's tags (4)
Silver
Andreas Lechner wrote:
Hello
best regards
Andreas
Do you have an ip helper defined on the segment which is causing the problem? Especially if your DHCP server is on a different segment to the one the windows 7 PE box is on?
Cheers.
yes the ip helper works fine.
dhcp also works fine in this network on all win xp and win 7 clients.
at the pxe boot the pc gets an ip adress, is loading the windows PE and in the windows PE it didnt get an ip adress when the pc is directly connected to the catalyst.
when we use a small noname switch between the pc and the cisco it works fine.
best regards
Andreas
Purple
  Do all your user ports have spanning tree portfast enabled on the ports ?
yes portfast is enabled on all access ports
Silver
I've done a bit of looking around, and this could be caused by a couple of things.
On the switchports you're plugging your PXE build nodes into, add the following command
switchport nonegotiate
and see if that helps.
if that doesn't work, look for the keyword "ip broadcast address XXXX" on your SVI or routing interface - if it's there, remove it with the "no ip broadcast address" command and see if that helps.
There's a Microsoft KB article which kinda supports the latter located here
http://support.microsoft.com/kb/928233
The first solution is more likely, as the "switchport nonegotiate" disables 802.1x negotiations on the port, which seems to be the bit which breaks the PE DHCP requests.
Oh, and make sure you explicitely specify the "switchport mode access" component in your port configuration.
Cheers.
hmm, switchport noneogtiate doenst help
i will search for the broadcast adress and post the results here
Silver
Well, now I'm stumped. Sorry. :-(
I am running into a very similar issue...did you ever find a fix?
hi matt,
maybe, the PCs are connected over a cat 7 Cable with tera/rj45 patch cables.
When the PCs are directly connected to the switch over a normal Cable (both sides rj45) it works fine.
we think that we have a problem with the cables.
Now we are waiting for new tera/rj45 cables
best regards
Andreas
2179
