Community Member
Catalyst 3560-X Netflow
I have a couple of Cat 3560-X Switches with the 10Gig NM module installed. I want to set up some Netflow on the 10Gig Link but I can't seem to get any stats exported to the collector.
I am running 15.0(1)SE IP Base
I have the following configuration
flow record ORION-REC
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect counter bytes long
collect counter packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter ORION-EXP
destination 172.18.18.3
source Vlan2
transport udp 2055
template data timeout 60
flow monitor ORION-MON
record ORION-REC
exporter ORION-EXP
cache timeout inactive 30
cache timeout active 60
cache entries 1000
interface TenGigabitEthernet1/2
description Link to xxxxxxxxxxxxxxx
switchport mode trunk
ip flow monitor ORION-MON input
ip flow monitor ORION-MON output
Catalyst-3-DR#sho ip flow export
Flow export v9 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       172.18.0.3 (Vlan2)
    Destination(1)  172.18.18.3 (2055)
  Version 9 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
Any help would be appreciated, I have seen a few people trying to set this up but not really seen anyone have much success with this yet.
1128
