03-16-2018 07:09 AM - edited 03-08-2019 02:17 PM
Sorry if I sound a bit dense here, I'm not the network guy, just a server admin who's had a switch decommission dropped into my lap and I need to get the task done.
We've got a Catalyst 3560G that we are decommissioning, and I need to perform a full factory reset, and what that means to most folks, I would think would be that any data / configurations that were previously set would be wiped out. I have come across factory reset instructions here but they all seem to retain a backup of the config. I don't want that...
So how do I, with this given hardware, and no other information, such as knowledge of the switch OS, how to connect to it, usernames, passwords etc... Get into this thing, get access to the firmware, and set the config back to the way it rolled out of the factory with no traces of any configs the network team has made over the years?
03-16-2018 08:06 AM
Hi dbosttexas,
How did you erase the config of the switch?
I recommend to run the following commands to completely erase the config from switch:
write erase
delete flash:vlan.dat
erase nvram:
After running these commands reload the switch, switch will prompt to save the config and you have to type "no".
03-20-2018 06:53 AM
I got timed out writing my last answer to you, sorry.... Let's try again.
I haven't managed to overcome the initial hurdles to getting into the switch. Namely, my laptop doesn't have a serial port, I don't have the serial to funny not quite crossover RJ45 cable to make the connection, and Microsoft wasn't kind enough to leave HyperTerminal on Windows 10... So no, I haven't been able to log into the switch at all yet.
It should be noted that I am not the "network guy", but rather a systems guy. This was handed to me because, well, honestly heck if I know. The network team won't touch it so it gets to me to get it done...
All things considered, failing a software approach, I guess I could go all Office Space printer on these switches and be done with it :-P
03-16-2018 08:16 AM
i do it in ci to be sure get in wipe everything
in cli # mode when you login
type
erase startup-config
then type reload and hit return do not save it , this will wipe all configurations
then go back in and go to flash
check it with either show flash: or dir flash:
it will bring up all the listed files stored, here delete one by one except the ios software itself
make sure to delete flash:vlan.dat which contains all vlan information and doesn't get wiped on the
you could do that first then erase startup command last either way just make sure you get everything
This will wipe the switch to factory , everything should go from flash except the .bin file which is the software
This is how you would connect to a Cisco switch from pc
https://www.youtube.com/watch?v=7sM4f1_QloQ
Any questions just ask
03-17-2018 06:47 AM
You can just press the mode button on front panel for few seconds until it will show you the prompt:
flash_init
Type this command flash_init and wait for few seconds more, delete the files with command delete flash:config.text if you really want to delete a d same with all other files after deleting all files just type boot and your switch is factory reset now.
