Catalyst 3750-24FS
I cant find out the wavelength of 100 Mbit interfaces for this catalyst. Is it 1310nm or 850nm?
Bronze
Re: Catalyst 3750-24FS
1000Base BX SFP,1310 nm on the 3750-24FX.
Here is the data sheet for the Cisco Catalyst 3750 :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
Thanks for the reply but the I need the wavelength for the Catalyst 3750-24FS. Here there are 24 fix 100 Mbit/s fiber ports.
I cant find out the wavelength on any data sheet for those fiber ports
The wavelength depends on the optical standard. Since the switch you are referring to comes with 100Base-FX standard the wavelength used will be 1300nm.
Minimum Wavelength - 1270nm
Maximum Wavelength - 1380nm
Fiber Type should be MultiMode and the core size can be 62.5 or 50 micron.
>> Sushil
444
