02-01-2017 06:51 AM - edited 03-08-2019 09:08 AM
I am trying to lab some BGP and have a few old switches available to me. I have a Catalyst 3750G and a Catalyst 3560, both are the 1st generation so can't run IOS 15.0. I have therefore upgraded them to 12.2(55)SE11 and enabled the 'routing' SDM profile. I have created a small network and configured BGP between them which is working fine. However I need the remote switch to send a community attribute to the other. I have configured an outbound route-map to match against an IP prefix list and then set a community. On the other switch I have an inbound route-map that matches this community and then sets a local preference.
Unfortunately this isn't working and it looks like the switch isn't sending the community. I have stripped back the configuration and configured the route-map to just set the community (rather than matching anything) and it still isn't working:
router bgp 65465
bgp router-id 10.1.1.1
bgp log-neighbor-changes
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
neighbor 10.1.2.1 remote-as 65303
address-family ipv4
redistribute connected
neighbor 10.1.2.1 activate
neighbor 10.1.2.1 send-community
neighbor 10.1.2.1 route-map ADVERTISE-OUT out
no auto-summary
no synchronization
exit-address-family
route-map ADVERTISE-OUT permit 10
set community 5555:1111
Is this just a limitation of this platform? Would this work with Catalyst 3650's?
Cheers
Andy
02-01-2017 08:36 AM
I have done a bit more debugging and sniffing and the switch IS sending the community. Therefore it must be the route-map on the receiving switch that isn't applying:
router bgp 65303
no synchronization
bgp router-id 10.1.1.2
neighbor 10.1.2.2 remote-as 65465
address-family ipv4
neighbor 10.1.2.2 activate
neighbor 10.1.2.2 send-community
neighbor 10.1.2.2 route-map BGP-IN in
no synchronization
exit-address-family
ip community-list expanded PREF-150 permit _5555:1111_
route-map BGP-IN permit 15
match community PREF-150
set local-preference 150
02-01-2017 08:51 AM
Have you tried to execute this command on both SW as Georg mentioned previously?
ip bgp-community new-format.
and to execute a clear ip bgp *
Regards.
02-01-2017 09:07 AM
I have already tried that and it has no effect. My understanding is that command only changes the readable format of communities in the output and won't change how the router operates?
02-01-2017 09:12 AM
Please let me lab it and share my outputs.
Regards.
02-01-2017 01:15 PM
I wonder if configuring the neighbors with:
neighbor x.x.x.x send-community both
makes a difference.
02-01-2017 09:23 AM
Just a question which prefixes are you advertising with that community? have you verified if the subnets are being received on the remote neighbor?
Regards.
02-01-2017 09:26 AM
If I remove the inbound route-map that is configured to match the community or if I add another line to the route-map so that processing continues it works, however the local preference is obviously not set which is what I want to achieve.
I expect this will be something silly like a typo on my part....
I'll keep looking.
Cheers
02-01-2017 09:28 AM
yeap, try to match any ACL on the route-map with the community.
02-01-2017 09:56 AM
Apparently the issue is with the regular expression, As I remember _ABC_ is regarding to AS but as 5555:1111 is not a BGP AS the community list should be:
ip community-list standard PREF-150 permit 5555:1111 ... The idea is mark and send the prefixes with LP 150 to the others BGP routers behind the AS 65303, right?.
My config
R1
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface FA0/0
no switchport
ip address 10.1.2.2 255.255.255.0
duplex auto
router bgp 65465
no bgp default ipv4-unicast
address-family ipv4
network 2.2.2.2 mask 255.255.255.255
exit-address-family
access-list 1 permit 2.2.2.2
match ip address 1
route-map ADVERTISE-OUT permit 100
R2
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FA0/0
no switchport
ip address 10.1.2.1 255.255.255.0
duplex auto
interface FA0/1
no switchport
ip address 10.1.3.2 255.255.255.0
duplex auto
router bgp 65303
neighbor 10.1.3.1 remote-as 65303
address-family ipv4
neighbor 10.1.3.1 activate
neighbor 10.1.3.1 send-community
neighbor 10.1.3.1 next-hop-self
exit-address-family
route-map BGP-IN permit 100
SW2#SH IP BGp
BGP table version is 5, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 2.2.2.2/32 10.1.2.2 0 150 0 65465 i
SW2#
SW2#SH IP BGp 2.2.2.2
BGP routing table entry for 2.2.2.2/32, version 4
Paths: (1 available, best #1, table default)
Advertised to update-groups:
Refresh Epoch 2
65465
10.1.2.2 from 10.1.2.2 (2.2.2.2)
Origin IGP, metric 0, localpref 150, valid, external, best
Community: 5555:1111
rx pathid: 0, tx pathid: 0x0
R3
R3#Sh ip bgp
BGP table version is 5, local router ID is 10.1.3.1
*>i 2.2.2.2/32 10.1.3.2 0 150 0 65465 i
R3#SH IP BGP 2.2.2.2
Not advertised to any peer
Refresh Epoch 2
65465
10.1.3.2 from 10.1.3.2 (1.1.1.1)
Origin IGP, metric 0, localpref 150, valid, internal, best
Please rate the comment if it is useful :-) thanks
Please try again.
02-01-2017 08:41 AM
try to globally configure:
3750(config)# ip bgp-community new-format.
