Community Member
Catalyst 3750-E Software recovery
I have the wrong code on the device.
I can get to the switch: prompt.
The manual say to cannect a PC to the management port.  But it does not come up.
xmodem does not seem to work.
I found some commands :
Examples
This example shows how to clear the Ethernet management port statistics:
switch: mgmt_clr
mgmt_init
Use the mgmt_init boot loader command to initialize the Ethernet management port.
mgmt_init
Syntax Description
This command has no arguments or keywords.
But they don't seem to work.  Any suggestions?
1 REPLY
Hall of Fame Super Gold
You've got two ways of fixing this:
1.  Cisco method:  Recovering Catalyst Fixed Configuration Switches from a Corrupted or Missing Image
2.  Quick-and-Nasty:  Get a USB stick, format to FAT16, copy the IOS BIN file into the USB stick (and pray the USB stick is "recognized") and stick it into the switch (at the back).  Use the command "boot usbflash0:IOS.bin".
Try to find SEVERAL USB stick <2Gb size.   If one is not recognize then try again with another stick.
610
