Catalyst 3750 - HSRP
I've implemented a LAN with Catalyst 6513 and a Catalyst 3750 providing for a redundant distribution layer. I use HSRP between these devices, but I see the Cat3750 only supports 32 VLAN interfaces.
The reason I went with the 3750 is that it is a much cheaper option to having 2 x 6513's.
Does anyone know of a possible workaround to this problem?
Dean
Re: Catalyst 3750 - HSRP
Hi Dean,
There is a hard-limit of 32 instances of HSRP on VLAN interface on this plattform.
This is a hardware limitation.
Ankur
Thanks. I am just puzzled as you can stack up to 9 3750's together.
Hi Dean,
The limitation lies the same even when 3750 are in stack.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swhsrp.htm#wp1069751
Its hardware limitation on stacked 3750 also.
Ankur
*Pls rate helpfull post
142
