Community Member
Catalyst 3750 monitor
set up monitor of an access port connected to a router. Only seeing traffic coming toward the switch from the router even though specified both. Any ideas...thx
1 REPLY
Re: Catalyst 3750 monitor
Can you try the following?
1. remove all SPAN config and then add it back
2. try span only tx direction to see if it works.
By the way, is it a single 3750 switch or a stack
115
