Catalyst 3750 Smartport Roles
I have 4 stacks of Catalyst 3750 switches for my LAN infrastructure, and they're all configured with multiple VLANs, QoS, etc. in conjunction with a Unified Communications system. On most of my client ports, I've applied the IP Phone+Desktop smartport roles, and likewise AP/Switch/Router roles for those devices.
My question is this-- is it appropriate to apply a smartport role on the switch ports connected to ASA devices (ie. can an ASA be treated as a switch or router)? If not, in addition to trunking, what other parameters should applied to those ports to optimally configure them?
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Blue
Re: Catalyst 3750 Smartport Roles
You can treat the ASA as a router to all intents and purposes. Although you talk about trunking, are you trunking yout switch to the firewall ?
Jon
Okay, personally i would just configure it manually because it makes sense to only allow the vlans you need on the trunk link ie.
int gi0/1  <-- this connects to ASA
switchport mode trunk
switchport trunk allowed vlan
Jon
Jon
Wow, thanks for the quick response!
I do, because I have some of my VLAN's crossing over WAN connections, and also some of my VLAN's haven't been reconfigured to use the router as the default gateway and instead are using the ASA.
Jon
Excellent, thanks for the help!
885
