02-29-2008 02:48 AM - edited 03-05-2019 09:27 PM
I have a stack of 2 catalyst 3750 and i have this situation:
#sh switch stack-ports
Switch # Port 1 Port 2
1 Ok Down
2 Down Ok
#sh switch neighbors
1 2 None
2 None 1
I would like to know if this situation is correct or not, I think is incorrect.
If it is incorrect, Can I change the stackwise interfaces?
02-29-2008 01:16 PM
You have sw1 stack-port 1 connected to sw2 stack-port 2.
Neighbors command shows that sw1 sees sw2 on sw1 stack-port 1, and vice-versa.
This is fine.
02-29-2008 11:26 PM
There is no problem....everything seems to be normal. Why do you thought its incorrect!!!
03-01-2008 12:03 AM
Paolo,
It would depend on whether you have connected both the stack cables between the switches.
As per your output there seems to be only one stack cable between the switches and is functioning normally
If you happen to connect the switches via both the stack ports, you would see something like below
MS_INDR_L3_SW1#sh switch stack-ports
1 Ok Ok
2 Ok Ok
MS_INDR_L3_SW1#
MS_INDR_L3_SW1#sh switch nei
MS_INDR_L3_SW1#sh switch neighbors
1 2 2
2 1 1
MS_INDR_L3_SW1#
Narayan
03-01-2008 03:25 PM
The problem is: the two stackwise are connected!!!
tnx for interest
03-01-2008 04:11 PM
Try reseating the connection. I know it's a pain to insert those cables and often the pins don't line-up properly.
If you reseat the cable and the problem persists, swap the cables and see if the problem follows the cable vs the stackports.
If the problem persists on the same stackports after changing the cable, you may have a faulty connector on either of the switches.
HTH,
__
Edison.
03-01-2008 06:28 PM
ok...
Very Very Tnx...
03-05-2008 07:50 AM
I have the same problem. I have tried lot of things allready - cable swapping, upgrade, downgrade. Problem is a half-duplex stackwise operation. It can be seen by the "show switch stack-ring speed". One pair of the ports are down and the others are on half-duplex.
03-05-2008 09:07 AM
I have just tried to connect third 3750 (older one). The result is - the third switch has always both ports up and the others have always down the second port. I tried to reconfigure the ring and the result is the same. Bad switches have always one port up and the second one down.
