Catalyst 3750 to 3560 via SFP
Could anyone tell me if I have a compatibility issue when connecting a Catalyst 3560 to a 3750 using a CAB-SFP-50CM cable?
Both switches have a C3KX-NM-1G network module fitted.
I used this cable to link 2 3560's with no problems, but when I try to use it on the 3750 I get an error saying that the port has been disbled because a non compliant gigabit interface converter has been detected.I'm only asuming that the CAB-SFP-50CM isn't compatible with the 3750.
I've got them connected via a RJ45 patchlead, but the SFP cable would look way cooler
Thanks in advance, Colin
1 ACCEPTED SOLUTION
Hi Colin,
It sound as is this cable only compatible with a 3560.
I found this [1]:
SFP Module Patch Cable
The Catalyst 3560 switch supports the SFP module patch cable, a 1/2 meter, copper, passive cable with SFP module connectors at each end. The patch cable can connect two Catalyst 3560 switches in a cascaded configuration.
Part NumberDescription
CAB-SFP-50CM=Cisco Catalyst 3560 SFP Interconnect Cable (50 dcm)
[1] http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml
Richard
Hi Colin,
I found this [1]:
Richard
Super Bronze
Re: Catalyst 3750 to 3560 via SFP
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
That special cable is supposed to only be used on 3560s, but I've wondered whether it might function with unsupported transceiver command.  Have you tried that?
Thanks for that, it's kind of what I thought.
Colin
312
