Catalyst 3750-X Series Switches
I have a Cisco Catalyst 3750-X Series Switches which would not boot up anyway. The info as below.
BAUD=115200
BOARD_CONFIG_REV=0
BOOT=FLASH:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin
CLEI_CODE_NUMBER=COMJV00ARD
DAUGHTERBOARD_ASSEMBLY_NUM=800-32727-03
DAUGHTERBOARD_SERIAL_NUM=FDO17150XET
MAC_ADDR=BC:16:65:FE:73:00
MODEL_NUM=WS-C3750X-24T-S
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-12530-08
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=FDO17150S1E
SDM_TEMPLATE_ID=0
SWITCH_NUMBER=1
SWITCH_PRIORITY=1
SYSTEM_SERIAL_NUM=FDO1715P1SS
TAN_NUM=800-31327-07
TAN_REVISION_NUMBER=B0
TERMLINES=0
VERSION_ID=V04
switch: boot
Loading "FLASH:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...FLASH:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin: no such device
Error loading "FLASH:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/update/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...@@@@@@@@@@@@@@.....
Error loading "flash:/update/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Boot process failed...
Anyone can help? Thanks.
Can you bring it to rommon prompt (by using the ctrl+brk) and use "boot flash:c3750e-universalk9-mz.122-58.SE2.bin"?
Make sure the image is in flah location. Else use the right image name.
Once it is up, check your start up config to see the boot command hardcoded.
HTH,
Nagendra
Hall of Fame Super Gold
The reason why your 3750X cannot boot is because of either there's no IOS or the IOS available is corrupt.
You'll need to completely download the BIN file from Cisco and verify the MD5 hash matches with your file.
Next, get a USB stick and (hopefully it's supported), format to FAT16, copy the BIN file into the USB stick and insert the USB stick into the sole USB slot in the appliance.
In ROMmon, enter the command "boot usbflash0:IOS.BIN".
963
