Catalyst 3750G 24-port PoE
My first thread. I have encounter some incompatibility on catalyst 10/100/1000Mbps POE switches.
My POE Device (PD) cannot be power up by 3750G (PSE). Found out that 3750G uses phantom power on pin 1, 2, 3, 6 which is IEEE 802.3af
Our 3rd party PD which is also IEEE 802.3af (similar to Cisco pre-standard PoE) uses spare pins 4, 5, 7, 8 for power only.
Anyway for the catalyst 3750G to power up using spare pins 4, 5, 7, 8 ?
Thanks.
Re: Catalyst 3750G 24-port PoE
I don't believe the 3750G supports power over those pairs, according to this whitepaper:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_white_paper09186a008026641c.shtml
All the while I thought Catalyst supports IEEE 802.3af Type A and Type B.
Type B be is similar to Cisco Pre-standard POE.
Any ideas I can convert Type A to Type B power delivery other than PowerDsine midspan switches ?
The reason i am asking is because I have devices which act as a backup and cannot be powerup until the master fail.
If i use just an injector or midespan switches which is dummy in nature, this will not work.
Best Regards
308
