Webcast-Catalyst9k
Catalyst 3750G stack
i've 2 Cat3750G connected into stack via 2 stack cables.
3750_Core#sh switch de
Current
Switch# Role Mac Address Priority State
1 Slave 000d.2975.3d80 1 Ready
*2 Master 000f.2490.af80 1 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 Down Ok None None
2 Ok Down None None
3750_Core#
in log i can see next messages-
*Mar 1 00:33:12.049: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:12.276: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:13.056: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:13.282: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:33:21.334: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:22.340: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:33:25.359: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:26.366: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:33:27.146: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:28.152: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:34.191: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:35.197: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:36.203: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:38.216: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:38.443: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:39.449: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:33:40.456: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:41.236: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:41.462: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:33:42.242: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:48.280: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:33:49.287: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:33:49.513: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:33:50.520: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
where is the problem and what does it mean?
Re: Catalyst 3750G stack
now those messages disappeared and switch information next-
Current
1 Down Ok None 2
2 Ok Down 1 None
Seems everythink is ok.
But before for a long time i got messages about UP and DOWN on console.
Which the reason was that messages and how to preserve against it?
when you connect a new 3750 switch on to the existing stack of 3750, which is running live, you get the UP & DOWN message(which is NORMAL), also the master switch will verify the additionally added switches IOS version, if there is a mismatch in the IOS version,the master switch will upgrade the IOS to slave switch & then reboots the slave switch, & even that time also you get the UP & DOWN message, this process usually takes 5-10mins when you add a new switch.
it was not new switch. They connected together and switch on. you can see log-
00:01:24: %SYS-5-RESTART: System restarted -- (3750_Core-2)
Cisco Internetwork Operating System Software (3750_Core-2)
IOS (tm) C3750 Software (C3750-I9-M), Version 12.1(11)AX, RELEASE SOFTWARE (fc3) (3750_Core-2)
Copyright (c) 1986-2003 by cisco Systems, Inc. (3750_Core-2)
Compiled Mon 21-Apr-03 11:37 by madison (3750_Core-2)
*Mar 1 00:02:07.218: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state UP
*Mar 1 00:02:08.225: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Mar 1 00:04:25.953: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:04:27.966: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:43:39.969: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:43:40.975: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
*Mar 1 00:44:07.142: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state UP
*Mar 1 00:44:08.148: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWN
3750_Core#$
3750_Core#sh swi
Current
*1 Master 000d.2975.3d80 1 Ready
2 Slave 000f.2490.af80 1 Ready
The message appeared again after 40 minutes.
A looked at the another stack ( which in production network) and here next information about stack-
3750G-CORE#sh switch de
Current
*1 Master 001a.e2c4.6980 1 Ready
2 Member 001a.e2d7.4c80 1 Ready
1 Ok Ok 2 2
2 Ok Ok 1 1
3750G-CORE#
You can see difference in Stack Port Status.
Any luck fixing this issue. I have two stacks doing the exact same issue. Only problem I have had that may not be related is all IP phones on one of the stacks have "reset" about 5 times. The phone just simply drop and come right back up like they drop the POE. Data stays connected.
Also -
3750_Core#
*Mar 1 00:34:58.730: %STACKMGR-6-STACK_LINK_CHANGE: Stack Port 2 Switch 2 has changed to state DOWNsh switch de
Current
1 Down Ok None None
2 Ok Down 1 None
Info about switches=
3750_Core#sh ver
Image text-base: 0x00003000, data-base: 0x006BA6CC
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
3750_Core uptime is 42 minutes
System image file is "flash:/c3750-i9-mz.121.11-AX/c3750-i9-mz.121.11-AX.bin"
cisco WS-C3750G-24T-S (PowerPC405) processor (revision B0) with 120822K/10240K bytes of memory.
Processor board ID CAT0806X0HL
Last reset from power-on
4 Virtual Ethernet/IEEE 802.3 interface(s)
48 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:0F:24:90:AF:80
Motherboard assembly number : 73-8046-05
Power supply part number : 341-0048-01
Motherboard serial number : CAT080607AM
Power supply serial number : DTH08060K9M
Model revision number : B0
Motherboard revision number : A0
Model number : WS-C3750G-24T-S
System serial number : CAT0806X0HL
Switch Ports Model SW Version SW Image
1 24 WS-C3750G-24T-S 12.1(11)AX C3750-I9-M
* 2 24 WS-C3750G-24T-S 12.1(11)AX C3750-I9-M
Switch 01
Switch Uptime : 40 minutes
Base ethernet MAC Address : 00:0D:29:75:3D:80
Motherboard serial number : CAT072504V7
Power supply serial number : LIT0718003A
Model revision number : A0
System serial number : CAT0725R0MD
you get this message continuously or it just shows in the log? because when you connect a additional switch, all these info will be in the switch log, stating the port is UP & Down, which is NORMAL.
i get those messages continiously. Is't normal?
can you connect console & tell me whether you get these messages still? if ur not getting it is NORMAL, if STILL you keep getting, then there is an issue.
306
