01-22-2014 08:15 PM - last edited on 03-25-2019 04:28 PM by ciscomoderator
Hi all,
We have a 3750 switch that I would like to monitor volume of traffic in a particular interface. I don't want to perform anything just monitor it. If anyone can help make this work I would appreciate it.
I have make a policy map that just defines some classes.
Before I start explaining, there is actual traffic going through int Gi1/0/5 that should match I have confirmed this with a port mirror.
What have done is setup the following:
policy-map QOS-MONITOR
class Transactional
class Voice
class Mission-Critical
class class-default
class-map match-any Transactional
match ip dscp af21
class-map match-any Mission-Critical
match ip dscp af31
class-map match-any Voice
match ip dscp ef
interface GigabitEthernet1/0/5
switchport access vlan 2
switchport mode access
bandwidth 10000
speed 100
duplex full
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
mls qos trust dscp
service-policy input QOS-MONITOR
end
The problem is I don't have any traffic matched e.g.
Service-policy input: QOS-MONITOR
Class-map: Transactional (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps
Match: ip dscp af21 (18)
0 packets, 0 bytes
5 minute rate 0 bps
Class-map: Voice (match-any)
0 packets, 0 bytes
Match: ip dscp ef (46)
0 packets, 0 bytes
5 minute rate 0 bps
Match: access-group name Voice
0 packets, 0 bytes
5 minute rate 0 bps
Class-map: Mission-Critical (match-any)
0 packets, 0 bytes
Match: ip dscp af31 (26)
0 packets, 0 bytes
5 minute rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
01-22-2014 09:11 PM
The show policy-map command does not work properly on Catalysts. Probably something due to using ASICs. You need to use show mls qos interface statistics instead.
Daniel Dib
CCIE #37149
Please rate helpful posts.
