12-16-2014 01:13 AM - edited 03-07-2019 09:54 PM
We have one Catalyat 3850 switch with High CPU utilization. I analysis "show proc cpu" result, the root cause of high CPU utilization is "FED" process.
I found the following documention mention how to troubleshoot the issue :
There are many show command, debug command and set commnad to enable detail tracking during troubleshooting step, does it cause any performance impact for the switch
Best Regards,
Jackson Ku
12-16-2014 01:24 PM
Jackson,
Can you post the output to the command "sh proc cpu sorted | ex 0.00"?
12-16-2014 04:53 PM
The show result :
switch#sh proc cpu sorted
Core 0: CPU utilization for five seconds: 7%; one minute: 8%; five minutes: 8%
Core 1: CPU utilization for five seconds: 2%; one minute: 7%; five minutes: 6%
Core 2: CPU utilization for five seconds: 4%; one minute: 11%; five minutes: 8%
Core 3: CPU utilization for five seconds: 99%; one minute: 98%; five minutes: 9 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5672 2559796 11225434 155 26.17 25.78 25.74 1088 fed
10187 2009764 10763907 145 1.72 1.72 1.62 34816 iosd
switch#sh proc cpu detailed process fed sorted | ex 0.0
Core 0: CPU utilization for five seconds: 7%; one minute: 11%; five minutes: 10%
Core 1: CPU utilization for five seconds: 6%; one minute: 11%; five minutes: 12%
Core 2: CPU utilization for five seconds: 1%; one minute: 26%; five minutes: 24%
Core 3: CPU utilization for five seconds: 98%; one minute: 65%; five minutes: 68%
PID T C TID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY
Process
5672 L 3033716 1122951 155 25.76 25.69 25.75 1088 fed
5672 L 3 10690 333099 1177069 0 24.39 24.32 24.41 0 PunjectRx
5672 L 1 6114 2387317 2458453 0 0.49 0.49 0.49 0 fed-ots-nfl
5672 L 1 6137 3616334 1229897 0 0.39 0.16 0.14 0 IntrDrv
5672 L 0 9630 3461270 3918786 0 0.24 0.26 0.26 0 Xcvr
5672 L 2 10691 3440665 5439261 0 0.15 0.19 0.19 0 PunjectTx
5672 L 1 6111 1258766 3461592 0 0.10 0.22 0.22 0 fed-ots-main
switch#show platform punt client
tag buffer jumbo fallback packets received failures
alloc free bytes conv buf
27 0/1024/2048 0/5 0/5 0 0 0 0 0
65536 0/1024/1600 0/0 0/512 100872100 100872100 1883447828 0
65537 0/ 512/1600 0/0 0/512 840586 840586 237664318 0 0
65538 0/ 5/5 0/0 0/5 0 0 0 0 0
65539 1/2048/1600 0/16 0/512 35974765 35974764 3935497384 0
65540 0/ 128/1600 0/8 0/0 0 0 0 0 0
65541 0/ 128/1600 0/16 0/32 461315396 461315396 3398385267 0
65542 0/ 768/1600 0/4 0/0 1758007 3591582 158315634 0
65544 0/ 96/1600 0/4 0/0 0 0 0 0 0
65545 0/ 96/1600 0/8 0/32 0 0 0 0 0
65546 0/ 512/1600 0/32 0/512 318361209 318361209 4044676185 0
65547 0/ 96/1600 0/8 0/32 0 0 0 0 0
65548 0/ 512/1600 0/32 0/256 277 277 17360 0 0
65551 0/ 512/1600 0/0 0/256 23 23 1515 0 0
65556 0/ 16/1600 0/4 0/0 0 0 0 0 0
65557 0/ 16/1600 0/4 0/0 0 0 0 0 0
65558 0/ 16/1600 0/4 0/0 0 0 0 0 0
65559 0/ 16/1600 0/4 0/0 0 0 0 0 0
65560 0/ 16/1600 0/4 0/0 0 0 0 0 0
65561 0/ 512/1600 0/0 0/128 529028955 593358770 2412522796 0
65563 0/ 512/1600 0/16 0/256 0 0 0 0 0
65564 0/ 512/1600 0/16 0/256 0 0 0 0 0
65565 0/ 512/1600 0/16 0/256 0 0 0 0 0
65566 0/ 512/1600 0/16 0/256 0 0 0 0 0
65581 0/ 1/1 0/0 0/0 0 0 0 0 0
131071 0/ 96/1600 0/4 0/0 0 0 0 0 0
fallback pool: 0/1500/1600
jumbo pool: 0/128/9300
12-22-2014 07:30 AM
02-02-2015 09:31 PM
08-20-2015 11:37 AM
Hi Jackson.ku
Where you able to solve your issue? Seems we are facing the same as described by you.
Greetings, Erich
08-20-2015 05:50 PM
We have raised TAC case and TAC engineer mention me it is known bug CSCuo98789. We upgrade to 3.3.5SE to resolve this issue.
Best Regards,
Jackson
08-21-2015 01:11 AM
Hi Jackson,
Thanks for your reply. The mentioned bug is not public available. But I have found the following int the release notes 3.3.x:
CSCuo98789 | 2 | ARP broadcast for vlan which is not SVI punted to CPU incase of Layer 2 |
My colleagues will try to update the switch as fast as possible. Sure it will solve the issue.
Greetings, Erich
09-15-2015 11:25 AM
Hi everyone, can you tell me
CAT3850/3650 UNIVERSAL
cat3k_caa-universalk9.SPA.03.07.02.E.152-3.E2.bin
will it solve our problem?
09-15-2015 11:36 AM
and what does it mean ?
show mgmt-infra trace messages fed-punject-detail
[09/14/15 19:06:56.576 UTC 1 6044] PUNT PATH (fed_punject_rx_retrieve_packet:1014):%RX Error: dropping packet in queue=1 buffer-len=192 FD_CONVERSION_FAIL
05-05-2016 08:11 PM
i'm facing High CPU utilization in our stack switches,here I 've posted the out put of the switches.
Please advice how to reduce the CPU utilization and what need to be done to normalize.
Thanks in advance
SW1#show processes cpu | ex 0.00
CPU utilization for five seconds: 32%/22%; one minute: 41%; five minutes: 46%
9 36995430 42139498 877 1.11% 1.75% 2.59% 0 ARP Input
203 1810068 4562646 396 0.47% 0.21% 0.17% 0 DHCP Snooping
207 18016262 47497509 379 2.39% 1.92% 1.94% 0 IP Input
247 780446 2900357 269 0.15% 0.06% 0.05% 0 HULC DHCP Snoopi
257 1522104 4299712 354 0.15% 0.10% 0.11% 0 DHCPD Receive
287 179 8240 21 0.63% 0.19% 0.04% 1 Virtual Exec
SW1#show version
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE8, RELEASE SOFTWARE (fc2)
Switch Ports Model SW Version SW Image
* 1 12 WS-C3750G-12S 12.2(55)SE8 C3750-IPBASEK9-M
2 28 WS-C3750G-24TS-1U 12.2(55)SE8 C3750-IPBASEK9-M
SW1#show processes cpu history
3333333333333333333333333333333333333333333333333333333333
0000000111112222299999888889999111110000011111333336666677
100
90
80
70
60
50
40 ************** *******
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
3445565565557885455458857765555545445656557975955657747855
9375269964412342775782228861000660998673201144931133061372
100 *
90 * *
80 ** ** ** * * *
70 * * *#* ** *#* * *#* * ** **
60 * **** *## ** *## *#* * **** ##* # * #* *#*
50 **#####***###**#**###*##**********####**###*#######*##*#
40 **########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
1 1 1 1 1 1 1 1 1 1 1 1 1
9909999999999909908907808795506505909909099908899996505595995696707797
9909999998999909904403409597403509906900096202890994906398999599108393
100 ****************** * * * * * ***** *** * * ** * * ** * * *
90 ****************** ** ** * * * *********** ***** * * ** * * *
80 ********************* ***** * * ***************** * * ** * ** *
70 *************************** * * ***************** * * ** *********
60 **************************** ********************#***** **************
50 #***************#####*******************#*##*#*###********************
40 ###*************##########********#***############**************######
30 #####***###################******##################*******#**#########
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Is this normal or abnormal?
How much percentage of CPU usage will really affect the switch performance?
05-05-2016 10:33 PM
Thanks. The outputs provided are very helpful.
41% is normal and I wouldn't be concerned about this. What is the "uptime" of all the switches?
05-05-2016 11:39 PM
Hi Leo,
Thankyou.FYI
SW1# uptime is 51 weeks, 5 days, 9 hours, 58 minutes
System restarted at 19:55:11 UTC Sat May 9 2015
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE3.bin"
Switch 02
Switch Uptime : 51 weeks, 5 days, 10 hours, 2 minutes
And recently we configured static route between these switch & another site switch via fiber ,after some time it worked fine and i have seen that tx load 96/255 rx load 26/255 in this switch,at that time theis switch crossed 100 percentage utilization.
How much Tx & Rx load will be permissible without affecting switch performance?
Thanks.
05-06-2016 01:12 AM
Until the counters for Output Drops starts incrementing.
Don't leave the switches up for more than a year without rebooting.
05-06-2016 08:16 PM
Thank you.
even Tx load 220/255,Rx load 208/255 also doesn't matter until there is no output drop or output drop increase in that interface right?
