10-15-2014 06:43 PM - edited 03-07-2019 09:08 PM
Can you advise where this 192.168.1.2 came from? This IP is not defined any where on the network.
TIA.
PF
sh user
Line User Host(s) Idle Location
2 vty 0 idle 00:01:01 192.168.1.2
3 vty 1 idle 00:00:53 192.168.1.2
4 vty 2 idle 00:00:00 192.168.1.2
* 5 vty 3 nnn idle 00:00:00 10.10.1.1
6 vty 4 idle 00:01:31 192.168.1.2
7 vty 5 idle 00:01:30 192.168.1.2
Interface User Mode Idle Peer Address
10-15-2014 07:37 PM
The IP address subnet 192.168.0.0/16 is a one of three PRIVATE IP address subnet.
The other two are 10.0.0.0/8 and 172.16.0.0/12.
10-15-2014 07:41 PM
Leo,
Thanks. I know it is a private range. We have not defined or use the range 192.16.0.0/16. I do not understand why sh user on the 3850 comes up with that IP and for some reason it uses a few of the vty lines as per sh user before.
PF
10-15-2014 09:22 PM
Check your management interface port.
If still not there, then disconnect the active VTY connections.
10-15-2014 09:52 PM
Leo,
Thanks. There is no management port (int mgmt). I did do a clear before but it just disappeared and reappear again.
clear line vty 0
Did a search on the config for the IP too but it is not there.
Thanks.
PF
10-16-2014 06:59 AM
PF
As a start for us would you post the output of show ip interface brief. Even better would be to post the configuration of your 3850.
Rick
10-16-2014 03:14 PM
Rick,
Thanks. Here is the sh ip int bri
sh ip int bri
Vlan1 unassigned YES NVRAM administratively down down
Vlan701 10.10.1.1 YES NVRAM up up
GigabitEthernet0/0 unassigned YES unset down down
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset down down
GigabitEthernet1/0/3 unassigned YES unset down down
GigabitEthernet1/0/4 unassigned YES unset down down
GigabitEthernet1/0/5 unassigned YES unset down down
GigabitEthernet1/0/6 unassigned YES unset up up
GigabitEthernet1/0/7 unassigned YES unset down down
GigabitEthernet1/0/8 unassigned YES unset up up
GigabitEthernet1/0/9 unassigned YES unset up up
GigabitEthernet1/0/10 unassigned YES unset up up
GigabitEthernet1/0/11 unassigned YES unset up up
GigabitEthernet1/0/12 unassigned YES unset down down
GigabitEthernet1/0/13 unassigned YES unset down down
GigabitEthernet1/0/14 unassigned YES unset down down
GigabitEthernet1/0/15 unassigned YES unset down down
GigabitEthernet1/0/16 unassigned YES unset up up
GigabitEthernet1/0/17 unassigned YES unset down down
GigabitEthernet1/0/18 unassigned YES unset down down
GigabitEthernet1/0/19 unassigned YES unset up up
GigabitEthernet1/0/20 unassigned YES unset up up
GigabitEthernet1/0/21 unassigned YES unset up up
GigabitEthernet1/0/22 unassigned YES unset down down
GigabitEthernet1/0/23 unassigned YES unset down down
GigabitEthernet1/0/24 unassigned YES unset down down
GigabitEthernet1/0/25 unassigned YES unset down down
GigabitEthernet1/0/26 unassigned YES unset down down
GigabitEthernet1/0/27 unassigned YES unset down down
GigabitEthernet1/0/28 unassigned YES unset down down
GigabitEthernet1/0/29 unassigned YES unset down down
GigabitEthernet1/0/30 unassigned YES unset down down
GigabitEthernet1/0/31 unassigned YES unset down down
GigabitEthernet1/0/32 unassigned YES unset down down
GigabitEthernet1/0/33 unassigned YES unset up up
GigabitEthernet1/0/34 unassigned YES unset up up
GigabitEthernet1/0/35 unassigned YES unset down down
GigabitEthernet1/0/36 unassigned YES unset down down
GigabitEthernet1/0/37 unassigned YES unset down down
GigabitEthernet1/0/38 unassigned YES unset down down
GigabitEthernet1/0/39 unassigned YES unset down down
GigabitEthernet1/0/40 unassigned YES unset down down
GigabitEthernet1/0/41 unassigned YES unset down down
GigabitEthernet1/0/42 unassigned YES unset down down
GigabitEthernet1/0/43 unassigned YES unset down down
GigabitEthernet1/0/44 unassigned YES unset up up
GigabitEthernet1/0/45 unassigned YES unset down down
GigabitEthernet1/0/46 unassigned YES unset down down
GigabitEthernet1/0/47 unassigned YES unset down down
GigabitEthernet1/0/48 unassigned YES unset down down
GigabitEthernet1/1/1 unassigned YES unset down down
GigabitEthernet1/1/2 unassigned YES unset up up
GigabitEthernet1/1/3 unassigned YES unset down down
GigabitEthernet1/1/4 unassigned YES unset down down
Te1/1/1 unassigned YES unset down down
Te1/1/2 unassigned YES unset down down
Te1/1/3 unassigned YES unset up up
Te1/1/4 unassigned YES unset down down
GigabitEthernet2/0/1 unassigned YES unset down down
GigabitEthernet2/0/2 unassigned YES unset up up
GigabitEthernet2/0/3 unassigned YES unset down down
GigabitEthernet2/0/4 unassigned YES unset down down
GigabitEthernet2/0/5 unassigned YES unset up up
GigabitEthernet2/0/6 unassigned YES unset up up
GigabitEthernet2/0/7 unassigned YES unset down down
GigabitEthernet2/0/8 unassigned YES unset down down
GigabitEthernet2/0/9 unassigned YES unset down down
GigabitEthernet2/0/10 unassigned YES unset down down
GigabitEthernet2/0/11 unassigned YES unset down down
GigabitEthernet2/0/12 unassigned YES unset down down
GigabitEthernet2/0/13 unassigned YES unset down down
GigabitEthernet2/0/14 unassigned YES unset down down
GigabitEthernet2/0/15 unassigned YES unset down down
GigabitEthernet2/0/16 unassigned YES unset down down
GigabitEthernet2/0/17 unassigned YES unset down down
GigabitEthernet2/0/18 unassigned YES unset down down
GigabitEthernet2/0/19 unassigned YES unset down down
GigabitEthernet2/0/20 unassigned YES unset down down
GigabitEthernet2/0/21 unassigned YES unset down down
GigabitEthernet2/0/22 unassigned YES unset down down
GigabitEthernet2/0/23 unassigned YES unset down down
GigabitEthernet2/0/24 unassigned YES unset down down
GigabitEthernet2/0/25 unassigned YES unset down down
GigabitEthernet2/0/26 unassigned YES unset down down
GigabitEthernet2/0/27 unassigned YES unset down down
GigabitEthernet2/0/28 unassigned YES unset down down
GigabitEthernet2/0/29 unassigned YES unset down down
GigabitEthernet2/0/30 unassigned YES unset up up
GigabitEthernet2/0/31 unassigned YES unset down down
GigabitEthernet2/0/32 unassigned YES unset down down
GigabitEthernet2/0/33 unassigned YES unset down down
GigabitEthernet2/0/34 unassigned YES unset down down
GigabitEthernet2/0/35 unassigned YES unset down down
GigabitEthernet2/0/36 unassigned YES unset down down
GigabitEthernet2/0/37 unassigned YES unset down down
GigabitEthernet2/0/38 unassigned YES unset down down
GigabitEthernet2/0/39 unassigned YES unset down down
GigabitEthernet2/0/40 unassigned YES unset down down
GigabitEthernet2/0/41 unassigned YES unset down down
GigabitEthernet2/0/42 unassigned YES unset down down
GigabitEthernet2/0/43 unassigned YES unset down down
GigabitEthernet2/0/44 unassigned YES unset down down
GigabitEthernet2/0/45 unassigned YES unset down down
GigabitEthernet2/0/46 unassigned YES unset down down
GigabitEthernet2/0/47 unassigned YES unset down down
GigabitEthernet2/0/48 unassigned YES unset down down
GigabitEthernet2/1/1 unassigned YES unset down down
GigabitEthernet2/1/2 unassigned YES unset down down
GigabitEthernet2/1/3 unassigned YES unset down down
GigabitEthernet2/1/4 unassigned YES unset down down
Te2/1/1 unassigned YES unset down down
Te2/1/2 unassigned YES unset down down
Te2/1/3 unassigned YES unset down down
Te2/1/4 unassigned YES unset down down
GigabitEthernet3/0/1 unassigned YES unset down down
GigabitEthernet3/0/2 unassigned YES unset down down
GigabitEthernet3/0/3 unassigned YES unset down down
GigabitEthernet3/0/4 unassigned YES unset down down
GigabitEthernet3/0/5 unassigned YES unset down down
GigabitEthernet3/0/6 unassigned YES unset down down
GigabitEthernet3/0/7 unassigned YES unset up up
GigabitEthernet3/0/8 unassigned YES unset down down
GigabitEthernet3/0/9 unassigned YES unset down down
GigabitEthernet3/0/10 unassigned YES unset down down
GigabitEthernet3/0/11 unassigned YES unset up up
GigabitEthernet3/0/12 unassigned YES unset down down
GigabitEthernet3/0/13 unassigned YES unset down down
GigabitEthernet3/0/14 unassigned YES unset down down
GigabitEthernet3/0/15 unassigned YES unset down down
GigabitEthernet3/0/16 unassigned YES unset down down
GigabitEthernet3/0/17 unassigned YES unset down down
GigabitEthernet3/0/18 unassigned YES unset down down
GigabitEthernet3/0/19 unassigned YES unset down down
GigabitEthernet3/0/20 unassigned YES unset down down
GigabitEthernet3/0/21 unassigned YES unset down down
GigabitEthernet3/0/22 unassigned YES unset down down
GigabitEthernet3/0/23 unassigned YES unset down down
GigabitEthernet3/0/24 unassigned YES unset down down
GigabitEthernet3/0/25 unassigned YES unset down down
GigabitEthernet3/0/26 unassigned YES unset down down
GigabitEthernet3/0/27 unassigned YES unset down down
GigabitEthernet3/0/28 unassigned YES unset down down
GigabitEthernet3/0/29 unassigned YES unset down down
GigabitEthernet3/0/30 unassigned YES unset down down
GigabitEthernet3/0/31 unassigned YES unset down down
GigabitEthernet3/0/32 unassigned YES unset down down
GigabitEthernet3/0/33 unassigned YES unset down down
GigabitEthernet3/0/34 unassigned YES unset down down
GigabitEthernet3/0/35 unassigned YES unset down down
GigabitEthernet3/0/36 unassigned YES unset up up
GigabitEthernet3/0/37 unassigned YES unset down down
GigabitEthernet3/0/38 unassigned YES unset down down
GigabitEthernet3/0/39 unassigned YES unset up up
GigabitEthernet3/0/40 unassigned YES unset up up
GigabitEthernet3/0/41 unassigned YES unset down down
GigabitEthernet3/0/42 unassigned YES unset up up
GigabitEthernet3/0/43 unassigned YES unset down down
GigabitEthernet3/0/44 unassigned YES unset down down
GigabitEthernet3/0/45 unassigned YES unset down down
GigabitEthernet3/0/46 unassigned YES unset down down
GigabitEthernet3/0/47 unassigned YES unset down down
GigabitEthernet3/0/48 unassigned YES unset down down
GigabitEthernet3/1/1 unassigned YES unset down down
GigabitEthernet3/1/2 unassigned YES unset down down
GigabitEthernet3/1/3 unassigned YES unset down down
GigabitEthernet3/1/4 unassigned YES unset down down
Te3/1/1 unassigned YES unset down down
Te3/1/2 unassigned YES unset down down
Te3/1/3 unassigned YES unset down down
Te3/1/4 unassigned YES unset down down
GigabitEthernet4/0/1 unassigned YES unset down down
GigabitEthernet4/0/2 unassigned YES unset down down
GigabitEthernet4/0/3 unassigned YES unset down down
GigabitEthernet4/0/4 unassigned YES unset down down
GigabitEthernet4/0/5 unassigned YES unset down down
GigabitEthernet4/0/6 unassigned YES unset down down
GigabitEthernet4/0/7 unassigned YES unset down down
GigabitEthernet4/0/8 unassigned YES unset down down
GigabitEthernet4/0/9 unassigned YES unset down down
GigabitEthernet4/0/10 unassigned YES unset down down
GigabitEthernet4/0/11 unassigned YES unset down down
GigabitEthernet4/0/12 unassigned YES unset down down
GigabitEthernet4/0/13 unassigned YES unset down down
GigabitEthernet4/0/14 unassigned YES unset down down
GigabitEthernet4/0/15 unassigned YES unset up up
GigabitEthernet4/0/16 unassigned YES unset down down
GigabitEthernet4/0/17 unassigned YES unset down down
GigabitEthernet4/0/18 unassigned YES unset down down
GigabitEthernet4/0/19 unassigned YES unset down down
GigabitEthernet4/0/20 unassigned YES unset down down
GigabitEthernet4/0/21 unassigned YES unset down down
GigabitEthernet4/0/22 unassigned YES unset down down
GigabitEthernet4/0/23 unassigned YES unset down down
GigabitEthernet4/0/24 unassigned YES unset down down
GigabitEthernet4/0/25 unassigned YES unset down down
GigabitEthernet4/0/26 unassigned YES unset down down
GigabitEthernet4/0/27 unassigned YES unset down down
GigabitEthernet4/0/28 unassigned YES unset down down
GigabitEthernet4/0/29 unassigned YES unset up up
GigabitEthernet4/0/30 unassigned YES unset down down
GigabitEthernet4/0/31 unassigned YES unset up up
GigabitEthernet4/0/32 unassigned YES unset up up
GigabitEthernet4/0/33 unassigned YES unset down down
GigabitEthernet4/0/34 unassigned YES unset down down
GigabitEthernet4/0/35 unassigned YES unset down down
GigabitEthernet4/0/36 unassigned YES unset down down
GigabitEthernet4/0/37 unassigned YES unset down down
GigabitEthernet4/0/38 unassigned YES unset down down
GigabitEthernet4/0/39 unassigned YES unset down down
GigabitEthernet4/0/40 unassigned YES unset down down
GigabitEthernet4/0/41 unassigned YES unset down down
GigabitEthernet4/0/42 unassigned YES unset down down
GigabitEthernet4/0/43 unassigned YES unset down down
GigabitEthernet4/0/44 unassigned YES unset down down
GigabitEthernet4/0/45 unassigned YES unset down down
GigabitEthernet4/0/46 unassigned YES unset down down
GigabitEthernet4/0/47 unassigned YES unset down down
GigabitEthernet4/0/48 unassigned YES unset down down
GigabitEthernet4/1/1 unassigned YES unset down down
GigabitEthernet4/1/2 unassigned YES unset down down
GigabitEthernet4/1/3 unassigned YES unset down down
GigabitEthernet4/1/4 unassigned YES unset down down
Te4/1/1 unassigned YES unset down down
Te4/1/2 unassigned YES unset down down
Te4/1/3 unassigned YES unset down down
Te4/1/4 unassigned YES unset down down
GigabitEthernet5/0/1 unassigned YES unset down down
GigabitEthernet5/0/2 unassigned YES unset down down
GigabitEthernet5/0/3 unassigned YES unset down down
GigabitEthernet5/0/4 unassigned YES unset down down
GigabitEthernet5/0/5 unassigned YES unset down down
GigabitEthernet5/0/6 unassigned YES unset down down
GigabitEthernet5/0/7 unassigned YES unset down down
GigabitEthernet5/0/8 unassigned YES unset down down
GigabitEthernet5/0/9 unassigned YES unset down down
GigabitEthernet5/0/10 unassigned YES unset down down
GigabitEthernet5/0/11 unassigned YES unset down down
GigabitEthernet5/0/12 unassigned YES unset down down
GigabitEthernet5/0/13 unassigned YES unset down down
GigabitEthernet5/0/14 unassigned YES unset down down
GigabitEthernet5/0/15 unassigned YES unset down down
GigabitEthernet5/0/16 unassigned YES unset down down
GigabitEthernet5/0/17 unassigned YES unset down down
GigabitEthernet5/0/18 unassigned YES unset down down
GigabitEthernet5/0/19 unassigned YES unset down down
GigabitEthernet5/0/20 unassigned YES unset down down
GigabitEthernet5/0/21 unassigned YES unset down down
GigabitEthernet5/0/22 unassigned YES unset down down
GigabitEthernet5/0/23 unassigned YES unset down down
GigabitEthernet5/0/24 unassigned YES unset down down
GigabitEthernet5/0/25 unassigned YES unset down down
GigabitEthernet5/0/26 unassigned YES unset down down
GigabitEthernet5/0/27 unassigned YES unset down down
GigabitEthernet5/0/28 unassigned YES unset down down
GigabitEthernet5/0/29 unassigned YES unset down down
GigabitEthernet5/0/30 unassigned YES unset down down
GigabitEthernet5/0/31 unassigned YES unset down down
GigabitEthernet5/0/32 unassigned YES unset down down
GigabitEthernet5/0/33 unassigned YES unset down down
GigabitEthernet5/0/34 unassigned YES unset down down
GigabitEthernet5/0/35 unassigned YES unset down down
GigabitEthernet5/0/36 unassigned YES unset down down
GigabitEthernet5/0/37 unassigned YES unset down down
GigabitEthernet5/0/38 unassigned YES unset down down
GigabitEthernet5/0/39 unassigned YES unset down down
GigabitEthernet5/0/40 unassigned YES unset down down
GigabitEthernet5/0/41 unassigned YES unset down down
GigabitEthernet5/0/42 unassigned YES unset down down
GigabitEthernet5/0/43 unassigned YES unset down down
GigabitEthernet5/0/44 unassigned YES unset down down
GigabitEthernet5/0/45 unassigned YES unset down down
GigabitEthernet5/0/46 unassigned YES unset down down
GigabitEthernet5/0/47 unassigned YES unset down down
GigabitEthernet5/0/48 unassigned YES unset down down
GigabitEthernet5/1/1 unassigned YES unset down down
GigabitEthernet5/1/2 unassigned YES unset down down
GigabitEthernet5/1/3 unassigned YES unset down down
GigabitEthernet5/1/4 unassigned YES unset down down
Te5/1/1 unassigned YES unset down down
Te5/1/2 unassigned YES unset down down
Te5/1/3 unassigned YES unset down down
Te5/1/4 unassigned YES unset down down
GigabitEthernet6/0/1 unassigned YES unset down down
GigabitEthernet6/0/2 unassigned YES unset up up
GigabitEthernet6/0/3 unassigned YES unset down down
GigabitEthernet6/0/4 unassigned YES unset down down
GigabitEthernet6/0/5 unassigned YES unset down down
GigabitEthernet6/0/6 unassigned YES unset down down
GigabitEthernet6/0/7 unassigned YES unset down down
GigabitEthernet6/0/8 unassigned YES unset down down
GigabitEthernet6/0/9 unassigned YES unset up up
GigabitEthernet6/0/10 unassigned YES unset down down
GigabitEthernet6/0/11 unassigned YES unset down down
GigabitEthernet6/0/12 unassigned YES unset down down
GigabitEthernet6/0/13 unassigned YES unset down down
GigabitEthernet6/0/14 unassigned YES unset up up
GigabitEthernet6/0/15 unassigned YES unset down down
GigabitEthernet6/0/16 unassigned YES unset down down
GigabitEthernet6/0/17 unassigned YES unset down down
GigabitEthernet6/0/18 unassigned YES unset down down
GigabitEthernet6/0/19 unassigned YES unset down down
GigabitEthernet6/0/20 unassigned YES unset down down
GigabitEthernet6/0/21 unassigned YES unset down down
GigabitEthernet6/0/22 unassigned YES unset down down
GigabitEthernet6/0/23 unassigned YES unset down down
GigabitEthernet6/0/24 unassigned YES unset down down
GigabitEthernet6/0/25 unassigned YES unset down down
GigabitEthernet6/0/26 unassigned YES unset down down
GigabitEthernet6/0/27 unassigned YES unset down down
GigabitEthernet6/0/28 unassigned YES unset down down
GigabitEthernet6/0/29 unassigned YES unset down down
GigabitEthernet6/0/30 unassigned YES unset down down
GigabitEthernet6/0/31 unassigned YES unset down down
GigabitEthernet6/0/32 unassigned YES unset down down
GigabitEthernet6/0/33 unassigned YES unset down down
GigabitEthernet6/0/34 unassigned YES unset down down
GigabitEthernet6/0/35 unassigned YES unset down down
GigabitEthernet6/0/36 unassigned YES unset down down
GigabitEthernet6/0/37 unassigned YES unset down down
GigabitEthernet6/0/38 unassigned YES unset down down
GigabitEthernet6/0/39 unassigned YES unset down down
GigabitEthernet6/0/40 unassigned YES unset down down
GigabitEthernet6/0/41 unassigned YES unset down down
GigabitEthernet6/0/42 unassigned YES unset down down
GigabitEthernet6/0/43 unassigned YES unset down down
GigabitEthernet6/0/44 unassigned YES unset down down
GigabitEthernet6/0/45 unassigned YES unset down down
GigabitEthernet6/0/46 unassigned YES unset up up
GigabitEthernet6/0/47 unassigned YES unset down down
GigabitEthernet6/0/48 unassigned YES unset down down
GigabitEthernet6/1/1 unassigned YES unset down down
GigabitEthernet6/1/2 unassigned YES unset down down
GigabitEthernet6/1/3 unassigned YES unset down down
GigabitEthernet6/1/4 unassigned YES unset down down
Te6/1/1 unassigned YES unset down down
Te6/1/2 unassigned YES unset down down
Te6/1/3 unassigned YES unset down down
Te6/1/4 unassigned YES unset down down
Thanks.
PF
10-17-2014 02:11 AM
During deployment 3850 in campus, also noted this fact... From personal experience, I believe that these strange session - console sessions when you are connecting console cable to the stack members switches or standby switch. Please note that you see the session type con 0 only if you are connecting console cable to the active switch.
For example, this is a stack of 4 3850 switch, and i sequentially connected by the console to the first switch, then the second, then the third and fourth... Next, I perform a command: show users
Here's the output commands:
c3850-2202#sh users
0 con 0 local idle 00:02:06
2 vty 0 local idle 00:03:44 192.168.3.2
3 vty 1 local idle 00:03:24 192.168.3.2
4 vty 2 local idle 00:02:36 192.168.3.2
* 5 vty 3 local idle 00:00:00 10.0.19.62
c3850-2202#sh switch
Switch/Stack Mac Address : 7c95.f365.5200 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member c025.5c12.5800 1 G0 Ready
2 Member c025.5c14.7800 1 G0 Ready
*3 Active 7c95.f365.5200 15 G0 Ready
4 Standby c025.5cb6.a980 14 G0 Ready
Why 192.168.3.2? Because active active switch in my case is number 3. I believe that in you case the active switch is number 1.
10-20-2014 03:56 PM
Thanks for your reply. Yes the active switch is 1. I believe you are correct about connecting to the console port on the switches. Can you advise how do we clear up these vty lines? Can you please advise why or what is the purpose of this IP or is this a bug? I have also noticed that vty lines used by this IP address varies as well. It could used up 3 - 5 lines.
TIA
10-21-2014 12:15 AM
Are this vty sessions constantly hanging, despite the fact that in reality nothing connected to the console?
In my case, i don't see this sessions after removing console cable from member or standby switch after the standard exec-timeout (10 min).
10-21-2014 03:21 PM
Aukhadiev,
Thanks for your reply. Nothing is connected to the console of any switches. I have tried clearing them but they will come back. They also automatically disappeared and reappeared.
10-21-2014 03:12 AM
We ve seen the same issue. Clearing them just brought them right back again.
Also, when they timed out after 2 minutes, they disappeared and came right back again.Weird.
Upgrading the switches helped. First upgrade to v3.3.0 and the vty sessions went away. We now upgraded to v3.3.3. btw.
I didn t understand either cause we dont use 192.168.0.0 at all.
The only thing i could think of was me setting up a VPN from my home (private network 192.168.1.0) and connected to the stacks at work. But then i use a company vpn ip, not my private home ip.
Like stated clearing the vty lines was not a solution, they just came back.
Issue goes away doing an upgrade.
10-21-2014 03:29 PM
Ton_vanengelen,
Thanks for your reply. The symptoms you described is what we are experiencing. It could be a bug then. We are running version 3.2.3. Will upgrade the switches and hopefully the problem will be resolved.
Thanks.
10-22-2014 12:12 AM
if you upgrade go to version 3.3.3 or higher. We run v 3.3.3 now, its working well.
Good luck!
10-22-2014 03:11 PM
