Catalyst 3kX Power Supply Mix-up
Can I mix up a 350 Watts PS and a 715 Watts PS on the same Catalyst 3kX switch?
Have you gotten an answer for
Have you gotten an answer for this?
Q. Can you mix power
Q. Can you mix power supplies in Cisco Catalyst 3850 switches? A. Yes. You can mix the power supply types either in a standalone switch or in a stack. That is, you can combine a 350W AC power supply (the default for a data-only switch) with a 715W or 1100W AC power supply (the default in a full PoE switch) or with a 440W DC power supply.
Thanks for the info. would
Thanks for the info. would you have a link for a document regarding this?
here mate,
here mate,
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/qa_c67-722110.html
HTH, please rate if helpful
103
